Front heater fan only working on 4
Re: Front heater fan only working on 4
Post by g8dhe » Tue Oct 03, 2017 3:57 pm
No thats for the electronic version, which controls a transistor with a bypass relay for the highest speed. Baz says he has an older mechanical slider version which uses the speed control resistors each resistor has its own thermal fuse and an additional one for the whole lot.
bongobaz
Post by bongobaz » Tue Oct 03, 2017 4:25 pm
That's the one Geoff.
Always be ready for a Top Up!
Post by g8dhe » Tue Oct 03, 2017 5:02 pm
Ah found the close up images couldn't see them for looking earlier!
The Electronic Climate control module is like this inside
Post by Northern Bongolow » Wed Oct 04, 2017 3:27 am
if you have it in your hand baz there are several little pieces of metal that are split and spread open to hold the plastic cover on the head. squeeze these together so the plastic cover comes off then you will see the desoldered springy legs that need resoldering, refit the cover and your sorted.
failing that i have one of each model here that i have repaired and dont need, i will pass them to ian or are you going to hope, you said you wernt going in the bongo but are you going.
bongobaz
Post by bongobaz » Wed Oct 04, 2017 12:38 pm
Yes going to Hope but not in my Bongo.
Post by Northern Bongolow » Wed Oct 04, 2017 1:46 pm
bring yer old one with you and i will do a free exchange, well the deal may involve a beer or a burger too. :lol:
