Coolant issues, air issues or something else?
Eye Guy
Re: Coolant issues, air issues or something else?
Post by Eye Guy » Mon May 08, 2017 4:27 pm
Ok. Here goes....
Apparently I have a worn universal joint at the rear prop shaft, which has caused the bearings to fall out. Causing the vibrations.
Garage has advised me to look for a second hand rear prop shaft and some near side rear half shaft gaskets (so they can fix the leaky rear differential at the same time).
Does that mean anything to anyone...? #-o :D
Post by Bob » Mon May 08, 2017 4:36 pm
Sounds like a call to Bongo Spares. 8)
Gasy
Post by Gasy » Mon May 08, 2017 4:38 pm
Easy job
Speak to the breakers they will have one in stock
Bongospares is well talked of on here
But do check the diff breathers arnt blocked on yours
Bongolia
Post by Bongolia » Mon May 08, 2017 6:54 pm
Well that is a good result at least you know what it is now.
Can they not fit a new UJ to the old shaft or is it to far gone?
The gaskets, if paper, can be cut from a bit of gasket paper or a corn flakes box.
Kellogs though, to maintain the quality.
Eye Guy
Post by Eye Guy » Mon May 08, 2017 7:46 pm
Ha ha :lol:
I'm Scottish. Nothing but porridge oats here.....
I did ask the question about replacing the universal joint and bearings but the mechanic seems to think I'd be better off replacing the whole lot.
Can I get the gaskets from the shop?
Bongolia
Post by Bongolia » Mon May 08, 2017 9:08 pm
I think Ian can get pretty much whatever you need. If its not listed give him a ring.
Post by teenmal » Tue May 09, 2017 10:13 am
A wee bit closer to home, the last time I looked they had 6/7 bongos breaking for spares.
When the mechanic said the vehicle required "near side rear half shaft gaskets " is there a possibility that they meant Oil Seals?.
auto recycling ltd
may robertson
AUTORECYCLING LTD MAIN ST MOSSEND
BELLSHILL
South Lanarkshire
ML4 1DX
United Kingdom
Phone:0777|1611057
Email:[email protected]
Eye Guy
Post by Eye Guy » Wed May 10, 2017 10:24 am
Thanks guys.
4WD rear propshaft ordered from bongo spares - arriving today :D
I did some digging and it is indeed the rear diff seals I need, not gaskets. I have ordered them from the shop.
Hopefully back on the road next week all being well.
Cheers and thanks again for help.
PS NB I mentioned about the diff breathers and will re-iterate when dropping off the seals. Cheers.
Post by teenmal » Wed May 10, 2017 1:18 pm
Eye Guy wrote:Thanks guys.
Aye, I was a wee bit worried that you got converted to corn flakes :shock:
Post by teenmal » Wed May 10, 2017 1:21 pm
I did some digging and it is indeed the rear diff seals I need, not gaskets I have ordered them from the shop.
Eye Guy
Post by Eye Guy » Mon May 15, 2017 10:09 pm
Got the Bongo back today. New rear prop shaft fitted (from Bongo Spares). He showed me the old one - the end was all split, no bearings left and about to totally break free! Just in the nick of time and all that.
Also had rear half shaft seals fitted (from the Bongo shop), new rear brake pipe and the diff oil filled up.
She sounds lovely again and driving really smooth :D
Just a £250 hole in my wallet to worry about now #-o
Post by Bob » Mon May 15, 2017 10:13 pm
That sounds good. =D>
Post by mikeonb4c » Tue May 16, 2017 9:37 am
Great news and worth every penny =D>
cmm303
Post by cmm303 » Thu May 18, 2017 8:20 am
You pay little in depreciation of these old vans but more on appreciation =D>
Chris with BertieB
