Re: Dull Headlamp
Posted: Tue Mar 14, 2017 5:02 pm
Its shouldn't do, as the outer surface has a plastic coating applied to it over the top of any seams so water penetration from outside should be minimal. The exception to this are the zips if the flap that covers them get folded back leaving them exposed to heavy rain it can penetrate a bit, but it only takes a little smoothing down with the hand as the zip is done ip to prevent this happening.
One thing with Bleach based products is rinse the material down with water afterwards so that the cotton fibres don't get damaged long term with the bleach rotting them, then just leave to air and dry naturally before closing the AFT down so choose the day for doing it carefully!
