Bongo keeps going flat!!!!!!
Re: Bongo keeps going flat!!!!!!
Post by Bob » Thu Mar 09, 2017 10:35 am
I recon Bongy is designed as a Faraday Screen to protect electrics from lightening. 8)
Gasy
Post by Gasy » Thu Mar 09, 2017 12:30 pm
For a faraday or arcamedies suit watch the you tubes vids of
Lords of lighting at Arcadia glastonbury
Amazing electric / lighting in a cow field
Might see me dancing as well :D
Gasy
Post by Gasy » Thu Mar 09, 2017 12:33 pm
Post by g8dhe » Thu Mar 09, 2017 3:02 pm
They ask about jump starting from another vehicle, because its quite possible in the worst case situation to cause damage to anything electronic in nature when jump starting, so they cover themselves by having it in the T&C's.
The problem comes that when connecting / disconnecting its possible (but very low risk) to generate a very high voltage spike that can destroy electronic components, vehicle electronics are designed with this in mind but even so its not an unknown occurrence.
gibbsy1969
Post by gibbsy1969 » Thu Mar 09, 2017 10:38 pm
Firstly thanks very much for all your help with my problem I have fitted the new unit which was a new one, this was surprising as i was expecting the old one to have be repaired maybe this in its self is an indication that the old unit was faulty and nothing to do with what i may have done.
So fingers crossed.
Dave
Bongolia
Post by Bongolia » Sat Apr 01, 2017 2:03 pm
Gibbsy did this sort your problem?
