Re: Changing from 2WD to 4WD
Posted: Tue Nov 01, 2016 9:58 pm
No LSD fitted, if there was you couldn't stop one wheel.
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
Prop shaft rotating? Put it in Park then other wheel should turn.Gripped wrote: So I jacked it up, put on stands. Put in neutral. Spun a wheel, the other stays still, no matter which side.
As it was safely chocked and on axle stands, I started her up. Both wheel spin, but you can stop either wheel with your foot and the other will spin.
What does this mean????
Try giving Bongospares.co.uk a quick call.Gripped wrote:Cheers will try that - yes the prop shaft turns if either wheel is turned.
I think the diff is ok (if a little whiney) but I am still keen to put an LSD in for my occasional off road trips. Combined with snow chains, I think it will handle most conditions with proper 2 wheel grip, instead of one spinning and one stopped.
Does anyone know what the approx. price of a used LSD is for a Bongo?
