Thanks that is what I now suspect. Not having anything to compare it too I assumed it was normal and it seems that its not, at least not unless the A/C is on etc.windywatson wrote:I would suggest that your engine has been running hotter than usual for some time. Nether of my V6's has the cooling fans come on that frequently that I regularly hear them. Only notice them running when Air Con is on. I would check that the thermostat is operating correctly. Not easy to do unless you have a good thermometer to check the temp at the top hose when the stat opens.
May actually be worth investing in a new stat anyway & having the coolant system flushed at time of fitting.
The stat was only renewed a year ago with a genuine Mazda item but as its overheated I will probably renew anyway as I work round the system.
