Won't start
Re: Won't start
Post by mikeonb4c » Tue May 03, 2016 7:54 pm
al & chris wrote:
mikeonb4c wrote:Great news it started ok. Did it run lumpy at all immediately after starting? How old is the battery?
Started up straight away, no lumpiness or rough running. Don't think it's its the battery, it's not new but it terns engin over well
Cool - that's eliminated that then. Be interesting to see if the problem stays away or returns. Is the fuel pump original / never been overhauled?
Re: Won't start
Post by Northern Bongolow » Tue May 03, 2016 8:26 pm
did you get good voltage when you tested it. could you not test at the plug/supply.
heres some good pics from an old ebay listing, it looks easy from the pics and it isnt that bad really.
http://www.ebay.co.uk/itm/mazda-bongo-2 ... 1378475851
al & chris
Re: Won't start
Post by al & chris » Wed May 04, 2016 12:02 am
Northern Bongolow wrote:did you get good voltage when you tested it. could you not test at the plug/supply.
Am I looking at right thing? On second picture looking from back of pump. Multi plug on top following black wire down to fuel cut off valve back right hand side from that view. All injector pipes make it so difficult to access from front when fitted.
Re: Won't start
Post by Northern Bongolow » Wed May 04, 2016 8:08 pm
yep thats the baby.
al & chris
Re: Won't start
Post by al & chris » Mon May 09, 2016 7:31 am
Well just done 250 miles this weekend with lots of stops and starts and no problems. Was half expecting a no start at some stage.
What was it? Could it have been a fuel blockage? Just hope it's gone for good. Thanks all for suggestions and advice.
Re: Won't start
Post by mikeonb4c » Mon May 09, 2016 8:14 am
al & chris wrote:Well just done 250 miles this weekend with lots of stops and starts and no problems. Was half expecting a no start at some stage.
Great news and fingers crossed it stays that way [-o<
