tappets
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Wed Jun 15, 2016 8:29 pm
Good evening all,
Has anyone had their hydraulic tappets replaced ? This tapping is bugging me know.
Re: tappets
Post by teenmal » Thu Jun 16, 2016 12:50 pm
Wilbaforce1 wrote:I will check the oil pressure though, cheers
What was the result...
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Thu Jun 16, 2016 8:52 pm
I have not had the pressure checked as I was told if the oil light goes out on start up, it is ok! My friend who owns his own garage took the sump off and found no sludge or anything like that. Tiny bit of swarf though. Still disheartening though. Bloody love my Bongo :(
Re: tappets
Post by teenmal » Fri Jun 17, 2016 7:08 am
Wilbaforce1 wrote:I have not had the pressure checked as I was told if the oil light goes out on start up, it is ok! My friend who owns his own garage took the sump off and found no sludge or anything like that. Tiny bit of swarf though. Still disheartening though. Bloody love my Bongo :(
Sorry that is not how it works,the light going out at start up only means that you have at least 6/7 PSI oil pressure (it only takes this amount of pressure to put the Light Out, personally (in these circumstances)if I went to the trouble of removing the sump I would have changed the oil pump valves, Can you not get your friend to check the pressure and run a gauge over the HLAs.
Take care.
Wilbaforce1
Re: tappets
Post by Wilbaforce1 » Fri Jun 17, 2016 12:06 pm
ah, maybe a glimmer of hope then, i will get the pressure checked, any idea what it should be please when its running correctly.
kind regards and many thanks, much appreciated.
W1
Re: tappets
Post by g8dhe » Fri Jun 17, 2016 1:44 pm
The engine manual specifies:
"J5-DE Standard value - 314 -529kPa (3.2 - 5.4kgf/cm2) - 3000rpm"
it does also warn that oil viscosity may affect pressure.
windywatson
Re: tappets
Post by windywatson » Thu Aug 04, 2016 10:02 pm
My 1997 V6 is a bit noisey on the top end as the Hydrolic lifters are noisey. Worst on start up improving once warmed up. I have used a product made by Wynnes specificly to help hyrdolic lifters & it does make a differance, well did in my case anyway. The van still runs well so living with it at the moment.
Windy-Watson
2001 V6 Tin Top
