Hold light on bongo cut out.
Jim the Box
Re: Hold light on bongo cut out.
Post by Jim the Box » Thu Feb 11, 2016 12:05 am
Just a mph overlay Mike. It's not chipped.
"Today's rain is tomorrow's Whisky"
05gt
Post by 05gt » Thu Feb 11, 2016 7:54 am
You could try taking it to campers Scotland in Grangemouth they are bongo specialists and do servicing and repairs as well as retail. Train station is nearby.
Post by g8dhe » Thu Feb 11, 2016 11:04 am
This isn't being over thought is it ?
It was heavy driving rain, it couldn't just be water up over the distributor, especially as it would have been on LPG at that point causing it to cut out ?
The Hold button just being pressed in error as implied in the explanation.
mikeWalsall
Post by mikeWalsall » Thu Feb 11, 2016 12:25 pm
Are the engine under shieldss in place as the TDC sensor is also vulnerable to road spray ..??
http://igmaynard.co.uk/bongo/forum/view ... on#p641855
Post by teenmal » Thu Feb 11, 2016 1:16 pm
Owing to the fact that the stalling seems to occur at the same time as the Hold light illumination I would be inclined to look for an auto box mal function. The possibility is that the converter or solenoids are not disengaging, (like driving a Manual vehicle and not pressing the clutch when the vehicle stops)it would be worthwhile having a Specialist doing a test scan on the box.
PS assuming that the fluid and filter are ok.
Post by g8dhe » Thu Feb 11, 2016 1:40 pm
If there was an actual problem with the box wouldn't the TCM be objecting and Flashing the Hold light ? OK it may not see all possible faults, but for the fault to be bad enough to cause it to stall then I would have thought an error would have been present ....
Jim the Box
Post by Jim the Box » Thu Feb 11, 2016 7:51 pm
Engine under shields are in place, however in the 4 years of ownership, the transmission oil has not been changed nor has the filter been changed, checked every 3 months, no leaks, fairly reddish no burnt toast smell, however had it not been sold on to the new owner (thriller) my 2 jobs for 2016 were to have been replace the hoses on the coolant system and, drop the sump on the gearbox and clean out the filter and change the transmission oil. From what I can gather it was driven all the way from Durham to Edinburgh without an issue, no flashing hold light or engine stall.
Post by teenmal » Fri Feb 12, 2016 6:02 pm
g8dhe wrote:If there was an actual problem with the box wouldn't the TCM be objecting and Flashing the Hold light ? OK it may not see all possible faults, but for the fault to be bad enough to cause it to stall then I would have thought an error would have been present ....
Hi Geoff,one of the reasons for my reply was...
When I spoke to you on Sunday it had cut out twice in a short space of time. Both times the van seemed to shudder and then I lost all power both these times the "hold" light flashed but I didn't notice how many times.
Post by g8dhe » Fri Feb 12, 2016 6:50 pm
Ah may have missed that :-( Must admit its not clear having re-read the thread if it was On or Flashing at various points, always a problem with intermittent things like this.
Jim the Box
Post by Jim the Box » Sat Feb 13, 2016 2:13 am
Haven't heard from "thriller" since he posted last week Geoff, so it may be the fault has disappeared for the time being, it's very difficult with an intermittent fault waiting for the hold light to start flashing.
