Earth Straps
Re: Earth Straps
Post by g8dhe » Sun Nov 15, 2015 10:37 am
The thin wire creates the initial magnetic field, its powered from the same fuse as the headlights, without it you will have problems!
Distilled Waters Run Deep
Re: Earth Straps
Post by Distilled Waters Run Deep » Thu Dec 31, 2015 9:52 am
Thanks all, the problem did turn out to be that the black-banded alternators aren't sufficient. I bought a used one from a breaker, & now I have 14.5 volts at the battery.
I love this car, but it's no longer practical for me so it's up for sale.... soon.... :lol:
Freda AFT: Haydn/Mason alarms + engine head temperature sensor.
Moto Guzzi California Jackal X reg
Re: Earth Straps
Post by Distilled Waters Run Deep » Sun Jan 03, 2016 8:32 am
Distilled Waters Run Deep wrote:Thanks all, the problem did turn out to be that the black-banded alternators aren't sufficient. I bought a used one from a breaker, & now I have 14.5 volts at the battery....
-Is 14.5v a sign that there is a regulator problem? -is that integral to a car alternator? -will that high a voltage harm any components or fry the battery? -if so, can I get a regulator I can fit inline?
Re: Earth Straps
Post by g8dhe » Sun Jan 03, 2016 10:57 am
14.5volts from the alternator is a bit on the high side, at high rev's 14.4volts could be expected, but once above 14.4v then gassing starts to occour and you will have Hydrogen and Oxygen being produced and electrolyte levels will start to fall as the water turns to the gases.
See http://batteryuniversity.com/learn/arti ... id_battery
Re: Earth Straps
Post by Distilled Waters Run Deep » Thu Jan 14, 2016 12:13 am
Thanks Geoff -14.5 is what I saw at high revs, I'll have another look soon to confirm. I suppose there may be a problem with my 2nd hand alternator then. I wonder if I could get away with fitting some sort of resistor inline?
Re: Earth Straps
Post by g8dhe » Thu Jan 14, 2016 11:37 am
Nah if that was at high rev's then 14.5v will be acceptable, all voltages when working with lead acid batteries are ±0.1v anyway, I was just concerned that it might have been at low to medium rev's!
The regulator is part of the alternator, so it would mean changing the entire unit again.
Re: Earth Straps
Post by Distilled Waters Run Deep » Fri Jan 15, 2016 12:22 am
Great, thanks!
I went for a little run, and without both back seats in the car... wow it shifts!
I still have a little niggle. The car has an Elsbett single tank veg oil conversion, and with the fully functioning alternator the electronic fuel pump doesn't work. If I remove the alternator connections, it will run, as it did with the under-powered alternator and the broken one. I don't have a wiring diagram to hand, so I don't expect any answers here... but I'll probably post here if I work it out, just for the record.
