Missing coolant
Gasy
Re: Missing coolant
Post by Gasy » Sat Aug 15, 2015 8:33 pm
I saw Donovan at glastonbury this year
Re: Missing coolant
Post by Bob » Sat Aug 15, 2015 8:51 pm
Wow, bet that was good. :D
Gasy
Re: Missing coolant
Post by Gasy » Sat Aug 15, 2015 9:15 pm
Yes he was
Sunday night in the aucustic stage
Marque was not that full
It was about all I could handle on Sunday night had been there for a week already
I was raved out
Had a lady come on stage and do a couple of songs with him , carnt remember who at mo just done 300 miles from devon
Me heads frazzled
Mrs has some pics I think
He don't look that old
scanner
Re: Missing coolant
Post by scanner » Sat Aug 15, 2015 10:23 pm
Q- What's the difference between Bob Dylan and Sir John Betjemen?
A- Dylan may be a better poet, but Betjemen's the better singer.
adey205
Re: Missing coolant
Post by adey205 » Mon Aug 17, 2015 8:32 pm
helen&tony wrote:Hi
A pressure test is the way to check if you have an invisible leak, and if it doesn't hold pressure, you need to locate the faulty hose. If it's the waterpump, you need to check with the engine off, and you'll often find traces of a drip when cold. You'll need a VERY bright torch to find the pump leak, and a mirror helps to look underneath the pump. Heater matrices are sometimes suspect , and you may find wet carpets at the front or a drip behind the drivers seat...don't use the aircon , as that will drip anyway. The seams on the radiator are also suspect...
Mike...the Donovan reference was on another thread :lol: ...
Have sat that van on a flat surface and ran for a while to get temp and see where possible leak is. It seems to be towards the rear of the engine so think I can rule out the pump. I have tried my best to identify pipework in that area but could with an exploded diagram so as to pinpoint the area.
Re: Missing coolant
Post by g8dhe » Mon Aug 17, 2015 10:30 pm
wonkanoby
Re: Missing coolant
Post by wonkanoby » Tue Aug 18, 2015 8:53 am
could be core plugs in rear of block
adey205
Re: Missing coolant
Post by adey205 » Tue Aug 18, 2015 7:15 pm
Think I may have cure it double dosage of Radweld Gold seems to have done the trick. From what I could see last night, I'm pretty certain its not core plugs. Tracing back water ascbest as I could it seemed to be coming from that block that mounts on the block/head
Re: Missing coolant
Post by Northern Bongolow » Tue Aug 18, 2015 8:20 pm
what year is yer diesel.??. new shape??.
this is the position of the core plugs in a late engine.
is it leaking around the gasket marked as 13 on this drawing. the gasket is to the egr cooler thats mounted on the side of the engine.
