Drawer Fridge Query
Re: Drawer Fridge Query
Post by g8dhe » Fri Jul 10, 2015 8:44 pm
Just seen the last post, no the lights should not go out the LB should still be connected, check back to the LB there should be an in-line fuse from the +ve terminal to a cable running into the van to the the Zig unit, suspect it might be blown!
yorksbob
Post by yorksbob » Fri Jul 10, 2015 8:51 pm
No, can't see any hefty cable running from the LB or the car battery. Regarding your last post, I will check the LB in-line fuse tomorrow and get back to you.
yorksbob
Post by yorksbob » Fri Jul 10, 2015 8:52 pm
Can you get these in-line fuses from most automotive parts shops?
yorksbob
Post by yorksbob » Fri Jul 10, 2015 9:13 pm
Success gentlemen!!!! It was an in-line fuse from the LB which wasn't seated correctly. I checked all the in-line fuses from the LB, pulled them out and pushed them back and lo and behold the fridge now works with or without the EHU.
Many thanks for all your help.
Post by g8dhe » Fri Jul 10, 2015 9:25 pm
That's good news!
Its worth occasionally pulling and re-inserting all the fuses (yearly say) as they can get damp and corroded on the contacts and a little bit of movement will disturb this and clear it out.
yorksbob
Post by yorksbob » Fri Jul 10, 2015 9:32 pm
Thank you for all that. One final point tonight: The terminals on the LB are clearly marked + and - but there aren't any clear + or - markings on the car battery; which one is which? One of the terminals has 2 cables running from it with what looks like earth wire colour code i.e green and yellow stripes. The other terminal only has one black cable running from it.
Post by g8dhe » Fri Jul 10, 2015 10:10 pm
The +ve of the Starter battery has the master fuse holder on it on a fixed arm, it will be on the left hand side / offside on the far side of the battery. The righthand side of the battery is the -ve, with one or two earthing cables depending on vehicle type.
Post by Simon Jones » Fri Jul 10, 2015 11:58 pm
It can only really be fitted and connected up one way.
tanglefoot
Post by tanglefoot » Sat Jul 11, 2015 7:19 am
Great news Bob... =D> As far as I remember...'+' battery posts are a bigger diameter that the '-' posts.....
yorksbob
Post by yorksbob » Sat Jul 11, 2015 12:06 pm
Thank you all for your help :D
