That's really interesting. So are you recommending we put water soluble oil in our cooling systems? I'd hoped that Mazda (and other OEM suppliers) produced water pumps with sealed-for-life bearings, but it sounds like I'm living on Planet IdealWorld againhelen&tony wrote:Hi
Mike
It was a common trick years ago, and well accepted. Mazda, and all other manufacturers stopped putting grease points on many components...it wasn't that they don't need it, but it was expense. Mr. Joe Public wants cheaper cars, so that's what he gets!....then it's up to him to service the damn' thing regularly (which he doesn't and complains if it goes wrong) All the necessary items that would have needed greasing then last until they drop, and need throwing away!...a bit of grease would prolong the life, but then Mr Joe Public complains of the time taken, and labour to service everything properly.Anything that has a bearing needs lubricating.
As for cutting oil , it's water-soluble, hence remains in solution, and whilst it's lubricity isn't like sewing-machine oil, or standard lubricant, it still offers help, and, yes, some water pump bearings are in contact with the fuid. There is no clogging, and it hasn't caused interference with the antifreeze!
In the end we drive cheap cars, because that's what Mr. Joe Public wants, then complains that it isn't a Rolls Royce...How many times have you heard of someone expecting a £2000.00 Bongo to give trouble-free service for years without touching much?????....and this is a car that cost thousands when new, and lke as not is all but worn out. Poor old thing needs resurrecting to thrive once more![]()
Still chuffing
Re: Still chuffing
- helen&tony
Re: Still chuffing
I caught your vid. clip
Doesn't sound like the spring seats (could be wrong)....That would make me think top mounts, or bushes somewhere?...lower arm / damper . Get it jacked up and get to work levering with a crow-bar
Re: Still chuffing
Thanks for the reply Helen. I've had it to pieces today. Arm bushes and all ball joints are fine. Didn't get shock out bit top mount looks good without excessive movement. I'm at a lose. Again!
- helen&tony
Re: Still chuffing
MMmmm....I've listened again, and IF....IF... it's not suspension, as you seem to have checked everywhere, have you looked in the engine compartment or under the bonnet?....It could be a loose mount somewhere, and when braking, the weight of the component shifts and makes a different noise?...I'd look at the larger components and the security of the mounting bolts?.... e.g. Steering?
Sorry to be vague, but I'm sure I've heard a similar noise....can't remember what it was!
Re: Still chuffing
how do you listen to it helen, when i click on the link i get the photobucket page etc but its just a blank screen, i can click next or previous and the pics are there.!!!!.
Re: Still chuffing
Northern Bongolow wrote:how do you listen to it helen, when i click on the link i get the photobucket page etc but its just a blank screen, i can click next or previous and the pics are there.!!!!.
You need to be patient, there is quite a long delay .
Re: Still chuffing
Listening to the recording it sound more like a Drive Related noise rather than suspension. Ie wheel bearing/CV/diff/etc etc.
PS along shot but it could be the mud flaps needing repositioned, check they are clear on full lock..
Re: Still chuffing
Thanks for the reply, only just seen it. I completely agree it sounds drive related, induced by braking and turning right. I've checked the bearings and diff and they all seem ok. The CV's I'm less confident on, however can't hear anything through the diff when listening by stethoscope (would it show up?).teenmal wrote:Listening to the recording it sound more like a Drive Related noise rather than suspension. Ie wheel bearing/CV/diff/etc etc.
Mudflaps would have been a possibility if I had any and I've checked the wheel arch liner etc.
An update to this, is as mentioned above I've inserted what Mazda call the bump stop (the thick rubber washer at the back of the front wishbone mount) and have heard nothing since. I don't know if that is it cured however as it is intermittent, I dared celebrate!
