Help please - Starter motor/Waeco cruise control
Re: Help please - Starter motor/Waeco cruise control
Post by Simon Jones » Mon May 18, 2015 8:16 pm
When you put the unit into test mode you should see the LED on the control box flash with each pulse. There is also a way you can check the actuator is working while in neutral and you should be able to increase / decrease the revs with the Set / Resume controls.
What happens at 15 mph? Does is stay at that speed regardless of Set / Resume being used to change the speed or if you drive at say 30mph and press Set does it then drop to 15?
Do you have a chip for the speedo like the one below? If so, you are better off taking the signal before it rather than after.
psquiddy
Post by psquiddy » Mon May 18, 2015 10:46 pm
I dont think it is going into test mode:
Hit brake to reset the unit.
Hold down set button while starting the engine then release.
Turn the c/c on - green LED comes on (not flashing)
Press the set button.
Nothing happens - LED still does not flash - holding the set button or repeated pressing makes no difference.
Pressing the set button at 15mph makes the c/c keep the car going at 15mph - I am not sure how good this is as I have not found a sufficiently quiet piece of flat road to do this on for any length of time - but at 15 mph something happens.
Driving at 30 mph and pressing set nothing happens - but I have not let it drop to 15mph from there as the roads around here are too busy.
There is no chip on the speedo.
Over 300 free things to do in London
http://www.toplondondaysout.co.uk
Post by Simon Jones » Mon May 18, 2015 11:34 pm
Have you gone thru Test A before moving on to B? The LED referred to is the one on the rear of the main module rather the switch unit.
psquiddy
Post by psquiddy » Tue May 19, 2015 4:02 pm
Yes - Test A checks out fine.
Post by Simon Jones » Tue May 19, 2015 9:13 pm
What are the results for Test B?
psquiddy
Post by psquiddy » Tue May 19, 2015 9:50 pm
