Rear fan blower..
Mickey Finn
Re: Rear fan blower..
Post by Mickey Finn » Wed Mar 18, 2015 2:27 pm
Found the problem. The fan and everything else down there is melted. Obviously from some botched welding job on the sill. Gutted.
Post by g8dhe » Wed Mar 18, 2015 3:27 pm
Probably get a replacement from George at BongoSpares if you wanted to http://www.bongospares.co.uk/
helen&tony
Post by helen&tony » Wed Mar 18, 2015 3:50 pm
Yes, I got a whole heater box from George... the heater matrix pipes snapped!!!!...luckily 7 kilometers from home!!!!!!The LCA saved the day, and I stopped in 100 yards!!!
Post by Simon Jones » Wed Mar 18, 2015 4:40 pm
Be aware that some point between 1999 & 2002 the size of the fittings for the A/C pipes changed so make sure you get a replacement unit from the same year as yours.
Mickey Finn
Post by Mickey Finn » Wed Mar 18, 2015 4:53 pm
Just ordered a complete unit from the Bongo spares place in Halifax. £60 quid, not bad. Perfect opportunity to change the coolant and get in the nooks and crannies with the waxoyl anyway. The fittings shouldn't be a problem. Mine is the early version with cables. Really appreciate the help guys.
Post by g8dhe » Wed Mar 18, 2015 5:01 pm
You can probably retrieve the fan motor, resistor pack etc. from the old one as well or has it been reduced to slag!
Mickey Finn
Post by Mickey Finn » Wed Mar 18, 2015 5:06 pm
The motor actually works, I hook it up to a supply. It clatters around in the molten surround though! The rest of the unit will have to stay in though. I need to use the vehicle till the new part arrives. How much coolant does a bongo system take? 50/50 mix ok?
silage
Post by silage » Wed Mar 18, 2015 8:09 pm
Check out the videos on bongo fury site for coolant refill etc :)
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
Post by Simon Jones » Wed Mar 18, 2015 9:40 pm
The coolant capacity is apparently 13 litres but as you can never drain it all out so you might just get 10 litres in so buy a 5 litre bottle and thoroughly flush it out. You'll also need to get the A/C refrigerant drained if you're taking the whole unit out which should be left to the professionals.
Post by Bob » Wed Mar 18, 2015 9:56 pm
Well done finding the problem. :D
Mickey Finn
Post by Mickey Finn » Wed Mar 18, 2015 11:06 pm
Hopefully the new one will arrive tomorrow. I'm still bewildered why the plug that powers the switch isn't showing a live. Anyone any ideas? The damage is too far down to affect the wiring. And the resistor on the unit looks fine.
helen&tony
Post by helen&tony » Thu Mar 19, 2015 4:59 am
Err..First time I attacked the rear heater, it was the motor gone, and I got one from a fellow member on here, but I did check out and clean the resistor, and the switch while it was out, and I replaced the dash switch by the driver's knee, and verified all the wiring.
Mickey Finn
Post by Mickey Finn » Fri Mar 20, 2015 8:27 am
Finally I have a working rear motor thanks to the lovely guys at Bongo Spares! Fitted the new unit, flushed and replaced the coolant contents and everything is dandy. Cheers for the help guys. I can see the light at the end of the tunnel with this thing...
Post by Bob » Fri Mar 20, 2015 9:24 am
Brilliant. =D>
