Busted Bongo
dandywarhol
Post by dandywarhol » Sun Oct 01, 2006 12:27 pm
This might not apply to your newer type engine Colin but will to '95 - 98 models
The duct tape is just to prevent further chafing, the clip has been "persuaded" away by gently levering the pipe to the rear by a couple of mm ...........
dreamwarrioruk
Post by dreamwarrioruk » Sun Oct 01, 2006 1:27 pm
ours was clear of the clip however there was a slight rub mark on the hose from rubbing with the small bore rubber pipe from the inlet manifold. 1995
J and J
Engine advice......
Post by J and J » Sun Oct 01, 2006 1:55 pm
Advice please, re Billie and her busted engine. My mechanic has tracked down a replacement engine, 28.000 miles removed from a tow truck, the engine is ok, year of manufacture 2002, probably ?850 + VAT is this worth persuing? or would a Bongo recon be better? Thanks
Jane and John (J & J)
dreamwarrioruk
Post by dreamwarrioruk » Sun Oct 01, 2006 2:15 pm
you say tow truck, does that mean its not a bongo engine.
if its either the ranger or the b2500 pick up you will find out that there are some significant differences.
firstly the above engines develope around 80 some bhp against 137 for the bongo.
the water bleed pipes are not found on the engines which are vital on the bongo. Ask pete humphreys about the problems hes had with his replacement (bongo) engine.
The turbo on the bongo is water cooled from the head and on the ranger and b2500 in sure that they arnt but that may have more to do with the extra bhp given out.
would try to steer clear if its not a gen bongo engine.
You could look at jalimports.co.uk
They say they have a range of replacement engines in but havnt dealt with them before.
J and J
Poor Billie
Post by J and J » Sun Oct 01, 2006 10:09 pm
Hi dreamwarrioruk,thanks for the information I shall inform mechanic and then try to source a Bongo engine,any other comments advice most welcome from everyone.cheers
Post by Ian » Sun Oct 01, 2006 10:27 pm
Bongo Towers recommends API Engines on 01926-614333. New & recon. DO NOT go down the Ranger route.
