Mysterious 20amp fuse blow (near passenger side battery)
Re: Mysterious 20amp fuse blow (near passenger side battery)
Post by g8dhe » Mon Dec 29, 2014 11:46 am
If you measure the current when "off" you will probably find around 50mA to 100mA with things on standby, like remote key fob receiver, radio backup etc. Any more than that then I dig down to find out what it is as like to understand where the power is being used ;-)
BongoBongo123
Post by BongoBongo123 » Mon Dec 29, 2014 1:20 pm
Sounds sensible no remote keyfob on mine.
They call me light foot.
Dodgey
Post by Dodgey » Mon Dec 29, 2014 2:28 pm
I have seen fridges kill leisure batteries. Even though they have low voltage protection, switching off when the battery is below 10.8volts, they keep trying to fire up every 30 seconds or so, fail, then repeat.
This eventually drags the battery down very low.
Sounds like you'd benefit from a solar panel and the regulator it somes with ;-) You'll never have a flat battery again.
BongoBongo123
Post by BongoBongo123 » Tue Dec 30, 2014 3:48 pm
Super quick delivery on that battery. I put new battery on awaiting new fuses to turn up. So far so good with the new one. Put old battery on for charge thinking it would be an ok spare and it takes current at 1A :shock: . Now as I recall good batteries take 4-5A when they are flat so I am fairly sure this battery has reached the end of it's life now. 1A seems very low like some cells are no longer taking capacity.
Post by g8dhe » Tue Dec 30, 2014 5:22 pm
Didn't the battery test out at about 2v ? If so it was dead and will never be revived! At a guess most of the cells are damaged well beyond any sort of use.
BongoBongo123
Post by BongoBongo123 » Tue Dec 30, 2014 11:15 pm
It did but I have no idea of what a "normally" flat battery reads at volts wise so thought it might be possible to revive, obviously not.
Post by Bob » Tue Dec 30, 2014 11:53 pm
Post by g8dhe » Wed Dec 31, 2014 11:22 am
The normal minimum is 11.8 volts, the absolute minimum is 10.8 volts but even by then the cells are starting to be damaged, less than that and the chemical reaction changes and can't be retrieved back to normal at all.
BongoBongo123
Post by BongoBongo123 » Wed Dec 31, 2014 11:35 am
Thanks for confirming, new battery was the right decision, must be very vigilant with the fridge off knob.
