Re: rattling tappets or fuel pump? ?
Posted: Wed Dec 17, 2014 9:56 pm
the pipe that connects to the top of the fuel pump diaphragm is the vac pipe to advance the pump when you rev it, yours is not connected. on your vid it shows it disappearing out of the bottom of the frame, it should go to the right of the vid frame and connect to the elbow on the air inlet manifold.
with this not connected the pump wont work right and the advance piston in the bottom of the pump could be flying around randomly, and maybe give you the noise your hearing.
item number 31 (bottom right) in the pump drawing in this link.
http://www.igmaynard.co.uk/bongo/forum/ ... mp#p533021
