Overhead storage
Dodgey
Re: Overhead storage
Post by Dodgey » Fri Dec 19, 2014 12:03 pm
the.sasquatch wrote:
philpdr wrote:Found a link to the plans I've got.Could be the same Vince.
http://homepage.ntlworld.com/vincent.lo ... oards.html
Amazing, thanks muchly =D> certainly going to be a time saver when making my own. This needs to be a fact sheet so it's easy to find :D
Not sure someone's free work should be put in a chargable document area (fact sheets)
I' build my own cupboards and I found it easiest to sketch up the sides, then the front, then the bottom, then finally the back, which bolts through to the grab rail bolt holes. Then I cut the sides out of cardboard, following the vehicle contours. After than it's just a case of cutting the long flat pieces.
The tricky part is the flush doors. You'll need a router and some practice!
Gasy
Post by Gasy » Fri Dec 19, 2014 6:41 pm
I agree
Post by Simon Jones » Fri Dec 19, 2014 6:54 pm
If someone wants to contact Vince and get his approval, then we can make a 'sticky' at the top of this section with the link to his web page.
dave_aber
Post by dave_aber » Sat Dec 20, 2014 7:41 am
Dodgey wrote:The tricky part is the flush doors. You'll need a router and some practice!
Or just make the entire outside face the 'door'
Image Image
Image...Image
helen&tony
Post by helen&tony » Sat Dec 20, 2014 8:55 am
Plans for overhead storage in fact sheet area is not on this Forum
There are links to plans on Bongo Wikee...but that's on another Forum... :wink:
dave_aber
Post by dave_aber » Sat Dec 20, 2014 8:59 am
Bongo Wikee is currently defunct.
Edit : Although i've been informed of its demise, it does seem to be working at the mo.
Can't find plans for top lockers though....
Image...Image
helen&tony
Post by helen&tony » Sat Dec 20, 2014 9:23 am
Dave...
I looked at Bongo Wikee half hour or so ago, and there was a link to Bongoforum on storage, I didn't check it out as I don't go to that forum...too busy!, but we don't have it on our fact sheets...
Any idea why the "Wikee" is down and defunct?...it looked like a bit of hard work went into it!
dobby
Post by dobby » Sat Dec 20, 2014 12:42 pm
Link is as per this post, does it need to be anywhere different?
Post by g8dhe » Sat Dec 20, 2014 3:01 pm
The wiki site used to be free, but they seem to have started charging for the site, so I guess someone must have had a word!
Snail921
Post by Snail921 » Sat Dec 20, 2014 5:42 pm
Are we talking about this page? http://mazdabongo.wikispaces.com/
If so it's working fine for me, at no charge.
Regards,
Brian.
Post by g8dhe » Sat Dec 20, 2014 8:15 pm
No it doesn't charge the user, only the people who set it up!
Supergoat
Post by Supergoat » Sat Aug 05, 2017 11:28 pm
I know this is an old thread but does anyone have the plans for cupboards- the link quoted previously is now dead:-
Thanks.
