- If you don't know what type of anti freeze you currently have, the safest option is to top it with tap water. Mixing coolant of different types (typically blue/green and red) can cause a nasty gunge to form.
- Consider getting coolant drained, system flushed and refilled with new coolant before the winter. It should be changed every two years unless you have used a longlife type which is usually good for 5 years.
- Get your coolant alarm fitted before you go to France as it won't do any good sat in the drawer at home
