280 miles to tank - about right or low?
larry787
Re: 280 miles to tank - about right or low?
Post by larry787 » Thu Jun 12, 2014 7:18 am
I have just filled ours up for the first time since we had it, its a 4x4 diesel auto and got 29.27 mpg and that was a mixture of town driving and "A" road cruising and im pleased with that
Post by Bob » Thu Jun 12, 2014 8:35 am
Pretty much what I get, happy too. :D
Post by rita » Thu Jun 12, 2014 9:01 am
Sounds good, what was the method of checking that you used.
larry787
Post by larry787 » Thu Jun 12, 2014 9:19 pm
I filled it up set the trip meter and filled it up again noting the mileage and did the maths
johnlewis
Post by johnlewis » Tue Jul 08, 2014 1:32 pm
Cheers peoples. So, if I'm looking about 20, what can I do to improve it? Seats are coming out soon so a bit of weight will be gained. Will it be:
Banjo filter
Fuel Filter
Air Filter
Anything else?
Gasy
Post by Gasy » Tue Jul 08, 2014 3:33 pm
Push it
philpdr
Post by philpdr » Tue Jul 08, 2014 8:30 pm
johnlewis wrote:Cheers peoples. So, if I'm looking about 20, what can I do to improve it? Seats are coming out soon so a bit of weight will be gained. Will it be:
Banjo filter
Fuel Filter
Air Filter
Anything else?
Trying not to rev over 2500 through the gears makes a big difference to mine.
mellon man
Post by mellon man » Tue Jul 08, 2014 10:33 pm
Anything else?[/quote]
Trying not to rev over 2500 through the gears makes a big difference to mine.[/quote]
Going to be hard that one as every time I see a VW van with side widows my right foot goes down to show them who's boss :P
Post by francophile1947 » Mon Jul 14, 2014 2:18 pm
Banjo filter
Fuel Filter
Air Filter
Anything else?
You still haven't said if you've properly checked the fuel consumption :? Until you do, it's all hypothetical, but filter changes are a good start.
al & chris
Post by al & chris » Mon Jul 14, 2014 4:57 pm
We are 4wd but can get 30mpg although average is 25mpg but it can be as low as 22mpg on short runs around home. Don't think 1 in 4 hill helps for setting of up.
BongoBongo123
Post by BongoBongo123 » Mon Sep 08, 2014 3:29 pm
Try and avoid it going down a gear through smooth and gentle acceleration technique, that immediately pushes revs through the roof, smooth driving. Judge distances in front and at junctions and roundabouts so you don't have to unnecessarily overdo the breaking.
Dump your water tank contents if unused before you leave your camp site or rest place for the journey home.
Air filter, Millers Diesel Ecomax diesel additive and regular servicing on the technical side will help optimize fuel consumption in all vehicles.
And a good quality injector cleaner used once every year or so should not do any harm to fuel economy and performance.
They call me light foot.
roosmith
Post by roosmith » Tue Sep 09, 2014 11:57 am
Banjo filter
Fuel Filter
Air Filter
Anything else?
As Francolphile says you have to do a proper test first, something would be very wrong to be getting that low. The fuel gauges are renowned for being inaccurate. Mine sits at 1/4 full for ages then just plummets. It could be you half a tank left in there.
Ours is a 4wd and we get more than 20mpg towing the caravan. I do have a heavy right foot and solo, very rarely drop below 25mpg.
Kelvyn
Post by Kelvyn » Thu Sep 11, 2014 10:20 pm
I get 20-22 using it as a short run in town daily driver, but have had 35+ on long slow, steady runs.
Vehicle Graphics, Signs & Print - http://www.ksdigital.eu
KTM 640 Adventure and Ford Freda
the1andonly
Post by the1andonly » Thu Sep 11, 2014 10:34 pm
97 4x4
Over 2 yrs get 21-22 mpg towing (980 kg ish trailer)
24-26 mpg general solo stuff
note variable rape seed oil ratio from 0% (on hols) to 30-50% at home or when poss,
within last year also add 300ml of 2 stroke oil to every 2- 3 tanks
Watty
Post by Watty » Sun Oct 12, 2014 7:38 pm
Filled up in mine today (2.5 V6 2001 Aero tintop, bought 4 days ago)- I clocked 398km since first fill up and when filling the tank put in 45.75 litres to fill it up again.
Putting that into old money I seem to have got 24.88mpg, which I'm pretty pleased with as I was only expecting about 20mpg from the V6. I drove pretty carefully, very rarely going above 2500rpm. I did put my foot down twice to overtake and was impressed by the power of the V6, but I think the mpg would tank if I drove aggressively all the time. It's nice to know it's got the power if I need it, but ambling along feels more appropriate for the Bongo.
