Page 2 of 2
Re: help no horn
Posted: Sat Oct 14, 2006 9:31 pm
by TrickeyDicky
rob and karen wrote:hi all was wondering if someone knew a fix for my problem , my horn has stopped working
cheers rob
:wink:
if i live feed the horn itself it works
:lol:
there is a coiled ribbon cable going onto a multi conector
PMSL
I fitted an extra horn on mine and it is very easy to wire a completely independent tooter
Fell on the floor
Honking your awning will draw attention for the wrong reason.
Simon - Thanks for the offer of a replacement horn
Passed out at this stage
Am I the only one to see the humour in this thread? Fnar Fnar :lol:
PS NOTE: I am not laughing at peoples bad luck just the humour contained within :wink:
Posted: Sun Oct 15, 2006 2:27 am
by bigdaddycain
Well spotted tricky dickey! i read the threads in all seriousness till you pointed out the double entendres, it must be the way your mind works, i,m too innocent to notice such things :oops: . i cant remember the last time i laughed so much! ... classic.
Toot Toot
Posted: Sun Oct 15, 2006 2:54 pm
by TrickeyDicky
Maybe this deserves to be moved in the jokes section :wink:
Is your horn working :?:
Moderator :wink:
Posted: Sun Oct 15, 2006 7:10 pm
by Dabs
When His horn doesnt work He uses His whistle :D
Dave
Posted: Sun Oct 15, 2006 8:56 pm
by David Edwards
Well I must admit.. it has been hard.. I have kept a stiff.. upper lip and tried not ..to rise to the occasion .. with the double entendres, tried to toggle mine up and down, waggled it round and round even gave the button a bashing. Went off in the end, nice to know my horn works as well as ever now. Happy motoring. ( I really am truly sorry but couldn't resist).
lol
Posted: Mon Oct 16, 2006 6:59 pm
by TrickeyDicky
LOL :wink:
Posted: Mon Oct 16, 2006 9:49 pm
by Dave up north
I have only got a little pathetic one
Anyone know how I can get a bigger one in???
:wink:
Spring loaded toggle switch.
Posted: Mon Oct 16, 2006 10:11 pm
by TrickeyDicky
Colin Lambert wrote:Don't panic.
I fitted an extra horn on mine and it is very easy to wire a completely independent tooter. (but you have to use a dash mounted, spring loaded toggle switch.)
You could always follow Colins lead :wink:
Posted: Tue Oct 17, 2006 7:54 pm
by Dave up north
I have just been given a big red one by a friend at work.
Its very impressive, about 10 inches long.
One problem. No instructions how to fit it.
Do I just wire it to the existing horn wires, or do I need a relay?
Its an air horn, I think. It has a metal cylinder then the long red horn.
Posted: Tue Oct 17, 2006 11:08 pm
by Colin Lambert
Dave,
I've got a big red one as well!
Is it like this Image.
If so and you want details and pics of fixing. e-mail me. DO NOT connect it to existing horn wiring. 1. it would need a relay 2. it is not legal. (so you need a legal horn for MOT and normal use.)
They make a brilliant noise though :wink:
horn
Posted: Sun Oct 22, 2006 10:03 am
by antique
hi if horn is not working and relay is try looking under drivers side front wheel arch trace wire from horn some times there is a scotch block connecter added, try a new terminal connecter and it will work?
