Re: Empty Expansion tank
Posted: Thu May 29, 2014 7:03 pm
Down by your right knee.
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
May have been badly maintained heater matrix could be blocked in consequence. I'd get a specialist to check it out as coolant system may not be functioning effectively.andyjohn3 wrote:Well the header tank is a dirty brown colour making it hard to see the level of coolant, but as mentioned in the youtube bleeding video, I was under the impression that pretty much all header tanks were the same!mikeonb4c wrote:Heaters should be pushing out hot air. I'd get a specialist to look at it before driving further. Is there evidence of (rust) staining in the header tank?
...but don't put too much faith in backflushing. On most occasions, Adrian at Japandirect told me, a new heater radiator is required. He showed me an old one he was changing and the crud was rock hard.wonkanoby wrote:there are 2 pipes going through the bulkhead to it
one in one out
as it warms they should both get hot
if one stays very much cooler the rads full of crud
back flush it with a hose
