New Shape Bongo Front Indicator Bulb Replacement
For pre 1999 the tube is a bog standard 210 mm (less pins) T5 tube. Available in Cool White, Warm white, and UV. In trade quantities they can be bought for around 75p.
Post 1999 Bongos use a T6 4 pin U tube 138 mm (less pins) also available in CW, WW, and BL (BackLight). Expect to pay at least a fiver for these.
The most common part number is FUL6T6 plus CW, WW, and BL.
Can we go back to changing the front lamps please, it's a lot more interesting.
I got round to removing the nearside front headlamp assembly today. It's fairly easy to do after you remove the radiator grill (I broke all 4 of the plastic lugs that hold the grill on in the process! - you need to depress a hook on the lug but the plastic seems to have become brittle and it just broke off). After removing the grill there are 3 bolts that fix the headlamp assembly to the body and then a fair amount of wiggling is needed to remove the assembly. Once out it's a simple matter to replace the indicator bulb and it also makes it a lot easier to change the headlamp and sidelight bulbs as well, especially if you have 2 batteries fitted.
As 2sticks has said, the interior light tube for the pre 99 model can be bought at most electrical stores. If you scroll down the page, it's the Philex 19213R 6W, on this link: http://www.philexproducts.com/philex_fl ... ories.html
