Re: Air lift rear suspension - big thumbs up
Posted: Thu Aug 22, 2013 11:30 am
Forgot to say - if you are fitting the valves at the rear of the step at the side door, there isn't any need to drill holes in the floor as others have done. When you remove the plastic step cover, there is a hole on the vertical panel at the rear of the step (covered with a bit of tape on mine). There is a corresponding hole on the vertical panel underneath the floor (might be blanked with a grommet) and it's easy to thread the pipework through the holes, with grommets to protect the pipes of course.
