Page 2 of 3
Re: Coolant alarm
Posted: Thu Apr 25, 2013 11:35 am
by rita
A long shot,have you maybe got the positive and negative the wrong way round.
Or the alarm might be too sensitive to the higher voltage.
Re: Coolant alarm
Posted: Thu Apr 25, 2013 11:57 am
by haydn callow
Mixing up the wires would not cause the alarm to sound.........having the sensor wire disconnected would......
Re: Coolant alarm
Posted: Thu Apr 25, 2013 12:36 pm
by Tidmo
Do you mean the header tank sensor?
Im totally confused here, may as well rip the thing out if it doesnt work properly.
Re: Coolant alarm
Posted: Thu Apr 25, 2013 12:47 pm
by haydn callow
Yes...if the header tank sensor wire is disconnected the alarm will sound......don,t rip it out.....it is a good bit of kit that could save your engine one day....
Re: Coolant alarm
Posted: Thu Apr 25, 2013 12:55 pm
by dom_e
Typo caused by auto correct in my previous post.
I posted an image of how my coolant alarm and Willinton kit was wired into the fuse board on your previous post about the Willinton kit. I was wondering if you wired yours like this?
Re: Coolant alarm
Posted: Thu Apr 25, 2013 1:05 pm
by Tidmo
dome-e- my willinton is currenly disconnected as is my coolant alarm. Til i get to the bottom of the bloody thing keep going off its going to stay that way.
Didnt see your pic but would be interested in seeing it.
To recap: New starter battery fitted (correctly) no fiddling/moving coolant alarm wires (yet), cleaned alarm screw, topped up coolant, alarm sounding constantly after initial chirrup on starting.
Sorry to go on but id like to try and sort it, the willinton kit and coolant alarm arent cheap pieces of kit but i feel like ive wasted a few quid here.
Re: Coolant alarm
Posted: Thu Apr 25, 2013 1:25 pm
by haydn callow
At the end of the day the alarm will prove to be working.......something has happened whilst fitting the battery/split charge kit....
No reason to rubbish 2 excellent bits of kit that hundreds/thousands of bongos have fitted.
Re: Coolant alarm
Posted: Thu Apr 25, 2013 1:27 pm
by haydn callow
If the alarm chirps/flashes when you turn the key before starting....it is fine.....
Re: Coolant alarm
Posted: Thu Apr 25, 2013 1:49 pm
by Tidmo
Dont get me wrong, im not rubbishing anything. Im just trying albeit frustratingly to get it sorted.
So by it chrirruping means its working okay how does it explain the constant sounding?
Feels like im going round and round in circles here.
Re: Coolant alarm
Posted: Thu Apr 25, 2013 1:59 pm
by rita
haydn callow wrote:If the alarm chirps/flashes when you turn the key before starting....it is fine.....
The clue might lie here....
Quote.....Coolant alarm chirrups as normal when ign first turned on and waiting for glow plug light to go out. All normal.
Now after the engine has started the alarm is constantly sounding.
The problem only seem to occur when the engine is switched on (Running)
Re: Coolant alarm
Posted: Thu Apr 25, 2013 2:12 pm
by Tidmo
Am i being incredibly dumb here or is that what ive said from the beginning.....
Re: Coolant alarm
Posted: Thu Apr 25, 2013 2:13 pm
by haydn callow
If I was in your position I would remove the alarm and refit it according to the instructions.
What is the voltage reading across the battery terminals with the :-
Key out of the ignition ?
Ignition on ?
Engine running ?
Re: Coolant alarm
Posted: Thu Apr 25, 2013 2:15 pm
by haydn callow
Then..
Measure the voltage between the sensor screw head and earth, again as above 3 times.
Re: Coolant alarm
Posted: Thu Apr 25, 2013 2:49 pm
by Tidmo
Okay Haydn, will try that and report back. Thank you.
Re: Coolant alarm
Posted: Thu Apr 25, 2013 6:50 pm
by Tidmo
Rewired as per instructions with live feed from fuse number 16
Volts across battery 12.65
Volts ign on 12.63
Engine running 13.92
Volts between sensor screw head and earth
Across battery 0.65
Ign on 8.65
Engine running 9.98
