Page 2 of 2
Re: front heater problem
Posted: Wed Mar 27, 2013 11:53 pm
by Northern Bongolow
front of the engine mate.
the edge can be seen at the passy side if you lift the seat. the problem is that the lower edge is hidden by the crankshaft pulley, so when it leaks out of the (telltale) hole at the 6 oclock position it goes undetected.
you need a dentist angle head mirror to see it.
Posted: Thu Mar 28, 2013 9:22 am
mikeonb4c wrote:Try squeezing your top hose. If it is hard and feels crunchy.......you have a crud problem :shock:
Out of interest, did you try the crunch test?
Posted: Thu Mar 28, 2013 10:36 am
by gartland
yes tried the crunch test .hose easy to squeeze .now going to search for the pump
Posted: Thu Mar 28, 2013 10:50 am
by wonkanoby
Follow the 2 belts on the alternator back to the engine
Posted: Thu Mar 28, 2013 10:58 am
by teenmal
gartland wrote:where is the waterpump situated #-o :?
Hi,what vehicle do you have.
Posted: Thu Mar 28, 2013 11:19 am
by gartland
1995 2.5 DIESEL
Posted: Thu Mar 28, 2013 11:34 am
by wonkanoby
lift drivers seat and dop as above
Posted: Thu Mar 28, 2013 11:38 am
by Simon Jones
Diagram of cooling system components: http://lushprojects.com/bongopartsmk2/c ... 2of02.html
Posted: Thu Mar 28, 2013 11:45 am
by teenmal
gartland wrote:1995 2.5 DIESEL
OK,if you stop the video at the front of the engine,the water pump(aluminium coloured) is above the crankshaft pulley(the big black thing at the bottom of the pic)It shows the water pump without the belts or pulley.
Good Luck..
http://www.youtube.com/watch?v=hMJQaN_8HGc
