A strange thing happened at B&Q
Dave up north
Post by Dave up north » Thu Aug 17, 2006 8:47 pm
:oops:
Naughty boy
alant54
Post by alant54 » Thu Aug 17, 2006 9:18 pm
What we all need to realise is that your battery will not last forever.....especially if it has run flat.....it will lose a lot of its capacity.....I think that Pippin mentioned this on an earlier post.......I think that the best solution is that if you have doubts about your battery the best thing is bite the bullet and splash out on a new one........expensive I know but could save a lot of heartache if your Bongo won't start......Alan
Alan...still plodding on....!
Dave up north
Post by Dave up north » Thu Aug 17, 2006 9:37 pm
Alan is right.
Also, I found that a voltmeter is not up to the job of testing a battery.
Not enough load.
Best to pop into a battery stockist and get your battery drop tested.
All t Best
Big Dave
alant54
Post by alant54 » Thu Aug 17, 2006 9:54 pm
Thanks Dave....I used to be an electrician but I think I am cured now according to my psy....phsy....sicia.....my shrink.....but you are right in what you say.....a full drop test on the battery is the only way to find out if it is going to let you down...Alan
pippin
Post by pippin » Thu Aug 17, 2006 10:06 pm
Did a drop test on mine, really simple thing to do.
Unfortunately there is battery acid all over the drive and I am now off work because my right foot is fractured in several places.
On the bright side it does not matter that my Bongo will not start (until I get a new battery) because I can't drive it with my leg in plaster!
Colin Lambert
Post by Colin Lambert » Thu Aug 17, 2006 10:57 pm
.--. .-. .- - :wink:
