Not according to my fridge manufacturer, maybe a compressor fridge would need less, it depends what you want to run. This is what I did, not how anyone else has to do it. I sized my cables for the length of run according to manufacturers' information. If it was the front socket smaller cables would be adequate. People have to do their own calcs for their own needs. The cost of the heavier cable wass virtually negligible, it just makes the routing a bit more challenging.Poohbear wrote:Isn't 6mm2 or even 4mm2 way overkill for this application? 2 x 2.5mm2 should be plenty big enough.Velocette wrote:I have done it this year. I think I used two 6mm cables,DILLIGAF wrote:read on here somewhere about upgradeing wire to rear 12v socket to run fridge or microwave, anyone done this? what wire do i need? and is it very difficult? any help would be appreciated.
You need a pair of ratchet crimpers, and very strong hands for crimping 6mm. You might get away with 4mm but it is quite a long run and the start up current of a fridge is quite high.
rear socket
Re: rear socket
Re: rear socket
I would guess that your fridge manufacturer would probably recommend wiring it directly rather than via a plug / socket?
Re: rear socket
No, it is supplied with a plug. I have used a John Dere type plug. The OP was talking about a microwave which is why I didn't suggest lighter cable. Mine is an absorption fridge and they do draw a lot of current.Poohbear wrote:I would guess that your fridge manufacturer would probably recommend wiring it directly rather than via a plug / socket?
Re: rear socket
Oh, makes sense nowVelocette wrote:No, it is supplied with a plug. I have used a John Dere type plug. The OP was talking about a microwave which is why I didn't suggest lighter cable. Mine is an absorption fridge and they do draw a lot of current.Poohbear wrote:I would guess that your fridge manufacturer would probably recommend wiring it directly rather than via a plug / socket?
- DILLIGAF
Re: rear socket
those pics and all the info will be a real help Velocette, thanks to one and all for the advice.
being a philosopher, i have a problem for every solution.
