You mean your "mistake".bongodonkey wrote:Sorry my bad is was 150/200ml not mm......![]()
Yes umbrage takenbongodonkey wrote:I take you would then take umbrage if I retorted....
WHATEVER....!!!
Not if it's incompatible it isn't, it could be a lot, lot worse.bongodonkey wrote:Not the same, as in the original fill. I worked on the premiss that proper anti freeze at this time of year is better than topping up with water.
