Page 2 of 3
Re: MADE IN JAPAN
Posted: Sat Sep 22, 2012 4:13 pm
by Colin H F
Thanks guys that should be of great help =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> Colin
Re: MADE IN JAPAN
Posted: Sat Sep 22, 2012 6:07 pm
by Colin H F
before and after the said bracket is no more, and I have a full 190mm depth
Re: MADE IN JAPAN
Posted: Sun Sep 23, 2012 11:00 am
by jaylee
Looks like yer prep'd up & ready to go! 8)
Re: MADE IN JAPAN
Posted: Sun Sep 23, 2012 11:30 am
by Colin H F
Yep sure am it should be here in a couple of days the the fun starts #-o #-o #-o #-o
Re: MADE IN JAPAN
Posted: Sun Sep 23, 2012 2:37 pm
by bongodonkey
Looking forward in seeing it on Friday Colin :mrgreen:
Re: MADE IN JAPAN
Posted: Mon Sep 24, 2012 12:27 pm
by Colin H F
wow it arrived this morning,not bad considering I ordered it 5pm friday, I have opened it and read the instructions, but there's nothing relating to the two angle brackets and 4 screws that came with it, I know its for securing the frame, but the screw holes don't align with anything on the frame,
Re: MADE IN JAPAN
Posted: Mon Sep 24, 2012 8:23 pm
by Colin H F
I have sent for the ISO adapter as the wiring in mine is a right mess, the original connectors have extended wires going to the connectors that went in the Jap radio and the colours don't match either, but one good thing the original 2 din cage fits a treat. so in the meantime I thought I'd put a supply on without the speakers just to see it illuminated, couldn't get it to do anything, so packed up trying, when I got in the house I realized I hadn't connected ACC wire, where does this come from and what does ACC stand for
Re: MADE IN JAPAN
Posted: Mon Sep 24, 2012 8:28 pm
by Simon Jones
ACC = Accessory which is the 12v switched feed from the ignition. definitely won't power up without it :)
Re: MADE IN JAPAN
Posted: Mon Sep 24, 2012 8:53 pm
by Colin H F
Thanks simon
Re: MADE IN JAPAN
Posted: Mon Sep 24, 2012 10:51 pm
by Colin H F
Couldn't wait curiosity gt the better of me ,, hooked it up in the house to check it out , DTV great reception .
Re: MADE IN JAPAN
Posted: Wed Sep 26, 2012 3:43 pm
by Colin H F
Update, Iso adapter came this morning £2.90 F + P checked the connections all good connected everything up and switched on set it all up Radio ,DTV, set time and date set car balance and mode, tried out everything except GPS & bluetooth al absolutely fantastic, a couple of questions now where and what type of sat nav for Britain do I need, whats KEY1 & KEY 2 there's a mention of 5volts. also why isn't the illumination cable fitted, on Geoffs wiring diagram it shows it as a red&black wire going to ISO A6, but in mine it has been disconnected from the bongo ISO and was fed via its own fuse from a wire that goes god knows where, when I cross reference 98 it opens page 66 and where the cable leaves the TNS relay contact it it seen connecting at several points with a solid dot but the connection to ref 98 is a hollow dot is this significant Geoff, http://www.g8dhe.net/bwm/bwmanualp.htm?1997/Page_66 Colin
Re: MADE IN JAPAN
Posted: Wed Sep 26, 2012 6:20 pm
by briwy
Fitting one of these has been covered before.
What you will probably have to do is move the GPS aerial socket (number 17) as it comes right where the big tube is in the back of the dash area.
Its easy enough to take the back off, drill another hole in it and move the socket over.
I got an adapter kit for the plugs off ebay, bit crowded getting all the wiring in but all goes in with a bit of care.
Re: MADE IN JAPAN
Posted: Wed Sep 26, 2012 9:04 pm
Colin H F wrote:.... a solid dot but the connection to ref 98 is a hollow dot is this significant Geoff, http://www.g8dhe.net/bwm/bwmanualp.htm?1997/Page_66 Colin
Mumm, never noticed these before explanation is here;
Top right - However it wasn't a section that was translated :-( Its not a standard symbol that I have ever come across - I have a suspicion that it might mean that the order of the wiring is not as shown, i.e. electrically its the same, but the practical sequence of the order of connection may be different from the diagram. I'll see if I can search out a translation !
Re: MADE IN JAPAN
Posted: Wed Sep 26, 2012 10:19 pm
by Colin H F
briwy wrote:Fitting one of these has been covered before.
I don't know why your mentioning this I haven't said I've got to move anything it fits perfectly!!!!!!!!!!
Re: MADE IN JAPAN
Posted: Thu Sep 27, 2012 11:01 am
by briwy
For some reason the second page of the thread wasn't there when I was looking at it so didn't realise you had already fitted it colin. Glad its sorted OK. Is the satnav IGo, most of them seem to be. If so the speed camera warnings from here can be loaded onto the SD card.
