Page 2 of 2
Re: rapesead oil/veg oil
Posted: Tue Sep 18, 2012 2:50 pm
by philpdr
Asian supermarkets/cash+carry places are pretty good.My local one currently has 20 litres veg oil for £17.99.
Posted: Wed Sep 19, 2012 1:04 am
by Titan1995
Just got back from the Bongo SW meeting. I used near 100% veg oil on both for the outbound and return legs of the trip.
Looking to fit a small aux tank for starting though...have sourced electrical isolator valves....
My Bongo appears to run much smoother on veg oil when motorway driving.
Posted: Wed Sep 19, 2012 10:39 am
by Diplomat
Has anyone any experience as to what percentage of vegetable oil causes non starting?
Mine refused to start at all when I had a large proportion of sunflower oil in the mix but the glow plugs had all failed. That was in July (if outside temperature makes a difference).
With no active glow plugs it had to be given a puff of starting aerosol (Ether?) first time each day for the few days until I did the plugs but it would restart quickly after that. Needless to say, I only put diesel in until I fitted the new glowplugs.
The previous time all my plugs failed it would start after a lot of cranking but in those days I was on plain diesel.
An extra tank seems overkill when there is bags of space under the bonnet to fit a 3 or 5 litre container to supply enough fuel for a few weeks of cold starting.
Frank
Posted: Wed Sep 19, 2012 11:09 pm
by chipvan
titan it will, before you add conversion make sure your insurance will take it on, you will need a 22 ltrs start up tank,a coolant heated heat exchanger,and 2 valves..
dont get cheap valves!
i can help you if needed.
Posted: Fri Sep 28, 2012 11:53 pm
by The Great Pretender
Posted: Sat Sep 29, 2012 8:50 am
by Hanksy
Ive just tried veg oil for the first time a couple of days ago....i just bought 20L of "crisp n Dry" from asda £2 for 2L and put it straight in the tank on top of about 1/3 diesel all has been good so far about 100-150 miles starts the same in cold mornings runs the same .....smells like a chip van though,
if i made a weaker mix would that smell go or is that the price to pay for cheaper motoring??
Posted: Sat Sep 29, 2012 9:00 am
by chipvan
nope the smell will always be there
Posted: Sat Sep 29, 2012 9:08 am
by Driver+Passengers
Hanksy wrote:Ive just tried veg oil for the first time a couple of days ago....i just bought 20L of "crisp n Dry" from asda £2 for 2L and put it straight in the tank on top of about 1/3 diesel all has been good so far ...
Did you put the whole 20L straight in? On a third of a tank of diesel, that's a strength mix of about 40-50%! For a first timer - you're a braver man than most!
Posted: Sat Sep 29, 2012 10:28 am
by Hanksy
Driver+Passengers wrote:Hanksy wrote:Ive just tried veg oil for the first time a couple of days ago....i just bought 20L of "crisp n Dry" from asda £2 for 2L and put it straight in the tank on top of about 1/3 diesel all has been good so far ...
Like A wise man once said Either DO or DO NOT, there is no try........Yoda.
So I did
although if I had realised the strength I Probally wouldn't of, ha ha
Posted: Sun Sep 30, 2012 2:47 pm
by Titan1995
I carried 50litres of the stuff on board to the NW Bongo Meeting......
Worked a treat for me on the long run to Cornwall.
Only use high % mixes on long runs when hot. Then put some diesel in when the other end to flush. Then go to the mix when hot.
A word of warning, veg oil will search out any weak seals on your fuel pump seals and exacerbate leaks.
I am in the process of having my pump resealed. I am assured by the Bosch [Zexel] engineers that veg oil won't be a problem for the newer seals.
Posted: Mon Oct 01, 2012 8:56 pm
by Gripped
I used the 20 litres of Asda rapeseed too. It was slightly misfiring when cold, so I topped the tank up with diesel so the mix was about 30% veg. No problems since. The oil needs to be thinned enough to allow easy starting.
I've decided never to go about about 50% veg, but in practice it will be 20 litres per full tank of diesel..... or 20 litres veg to 45 litres diesel.
Hopefully the fuel pump will prefer it.
Did my first MPG test on 30% veg and got 27 mpg, so about the same as normal.
Posted: Wed Oct 03, 2012 9:49 pm
by David Edwards
It is all about trial and error and what suits your bongo best, hard to believe it is about 8 years since I caused the price rise of cooking oil,lol.
