A man after my own. Its a rust build-up, not a grinding issue. Cleaned up all components, wire brushed off loose rust etc., blew off with airline and lightly regreased with coppaslip as educated to do from advice on here. Just lack the means to restore the rusted section of discs, but its only a minor proportion, and brakes work fine.mikexgough wrote:Yep I would go with that...... I tend to go for Allied Nippon brand..... who make the pads for Mazda,Toyota,Nissan,Lexus,Mitsubushi & Brembo among others..... Normally I dress up discs it they are okay that is..... a decent clean up of all the brake components blow out with the air line & re-grease on assembly on the parts that require it and there you go...... an extra 10 mins each side....attention to detail....dave_aber wrote:All I can think is that some time in the past either a set of pads was fitted with a smaller pad on the inner / piston side than the outer side, allowing that bit of the disk face to build up the corrosion - or at some point a set of pads has been used right down to the metal and ground that area first for some reason.
Thanks for the debate everyone - its all educational
