door loom
jaylee
Re: door loom
Post by jaylee » Tue Sep 04, 2012 9:01 am
Great write up Helen! 8)
Hope you don't mind a little input from me..?!! :mrgreen:
Be careful when removing the window switch with the lever technique. There is a plastic jutting out bit/clip on the front that has a tendency to break..!
Passenger switch back shown here.
If after removing all the door card screws & popping the fasteners along the bottom pulling the door card out slightly, you reach your hand up between the back of the door card & the sheet plastic membrane, follow the contour till you get to the switch loom & find the metal clip at the back of the switch.. Simply press the metal clip & pop the switch out!!
This will/should avoid any potential disappointment breaking the plastic clip on the front.. :idea:
helen&tony
Re: door loom
Post by helen&tony » Tue Sep 04, 2012 11:55 am
Hi Jay
That's actually what I did...so I'll amend that...I previously snapped the front plastic on the passenger side one...BUT the driver's one on mine has 2 spring clips...one front, one back?...anyway...as you say...forewarned is good!
