where to buy heads?
Re: where to buy heads?
yep----------------- or fit a flat cap, or fit an old cap with the seat cut in half with a grinder.if you dont it will allow inflation but will not register the pressure drop as its held between the cap seal and the inflater valve/gauge.
or you can just remove the bleed pipe bung and inflate from this end, and test the cap at the same time.
- dandywarhol
That's how I see it - inflating to 12 - 15 psi proves nothing but the space between the bicycle valve and the pressure cap is leak freeNorthern Bongolow wrote:yep----------------- or fit a flat cap, or fit an old cap with the seat cut in half with a grinder.if you dont it will allow inflation but will not register the pressure drop as its held between the cap seal and the inflater valve/gauge.
it will inflate the system and show any leaks provided you look for them, but this will not be obvious from just looking at the gauge as the pressure wont drop.
i dont know if its worth the time/effort/money/risk to bother with any old head, ive seen several that have lifted after failing to the extent that they have pinched the cam shaft bearings and grabed/snapped the camshaft in several places, so im not sure a skim would be worthwhile.Jimbob738 wrote:I have just been on ebay looking at complete cylinder heads as i want this put to bed quickly i want to get some holidays in this year and think i am going to buy it have asked seller some questions, its alot of money but so was my bongo and it deserves it tbh.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0713255713
any opinions welcome, the way i see it i have a 2nd head to rework over the forth coming year and if anything ever happens god forbid i wont have to flap like i am now!
Jimbob738
- Location: Jaaaaacksdale! but a nottingham boy throught and through! you reds
ok thanks for your views i will see whats what when i get it off the road first i think pressure test the system as everyone has said lots of please it could be leaking my bongo isnt overheating or smoking so it may not be the head at fault i will check for leaks first and change the water pump and the stat i have new kit ready and i have just ordered a new set of hoses that should be here next Monday so i will change all that see how i go on, the only issue im having is about 800ml of water loss after two or three days hard use its not overheating so hopefully with these works sorted i can stop in leaking from somewhere.
Booked next thurday and friday off work so ill update everyone after that.
- dandywarhol
I find the dye test in the expansion tank to be pretty accurate - detects CO2 in the system
Jimbob738
where can i get this dye i have the UV stuff but wasnt enough for 13 litres in the bongo so was gonna buy more but think if i can get tesing dye for CO2 then thats what i want ?dandywarhol wrote:I find the dye test in the expansion tank to be pretty accurate - detects CO2 in the system
- dandywarhol
- haydn callow
Hmmmmm....forgot to mention the pressure cap....I use a plain cap for testing
Jimbob738
Found the cylinder head testing kit like the link above local to me for 35 quid going to collect tomorrow.
- dandywarhol
Good price. Some kits only allow the dye to be used once - the Sealy kit allows numerous attempts.
Jimbob738
.dandywarhol wrote:Good price. Some kits only allow the dye to be used once - the Sealy kit allows numerous attempts.
so does this one bonus 2 mins from my work place found in on fleabay earlier
http://www.ebay.co.uk/itm/UNIVERSAL-BLO ... 2a15e9eb59
- Simon Jones
<insert northern stereotype comment here and retreat to a safe distance>Northern Bongolow wrote:---------------- or fit a flat cap
