a novice fitting glowplugs
mikeWalsall
Re: a novice fitting glowplugs
Post by mikeWalsall » Sun Nov 06, 2011 4:19 pm
Thanks ... for the explanation ...
It's just to my mind ... if you torque a bolt down to down to say 256 lbs foot .. then use an angle gauge .. you are simply apply more torque to 'stretch' the bolt anyway ..
So I could not see why a simple three stage tightening sequence with the torque wrench would not have achieved the same effect ..
Post by g8dhe » Sun Nov 06, 2011 6:06 pm
Using a torque wrench only ensures that you don't over tighten a bolt, its a measure of the rotational force that has to be overcome to turn the bolt due to friction.
Angular tightening is about applying a clamping force along the length of the bolt, as it is stretched by the length that Steve described previously.
Post by rita » Sun Nov 06, 2011 6:26 pm
widdowson2008 wrote:
g8dhe wrote:I think you will find that when the bolt starts to stretch the Torque required may well REDUCE, by angle tightening you force the bolt to stretch by a given amount in length.
The reason it's done by the angle tightening is as Geoff said, that is when the bolts actually START to stretch. The bolts are made of a very strong material (high tensile) which, for a given stretch produces are finitely known grip force. The actual bolt stretch is very small yet the grip force is identical in each bolt. VERY PRECISE.
The ONLY place I disagree with Geoff is the torque.. It certainly DOESN'T reduce in the final tightening. It goes WAY beyond the initial torque setting. Take my word for it Geoff. Been there - Done that. There is no way you can do the final 'stretch' using an ordinary torque wrench.
We had to use a 5 foot pipe to complete the final 2x90 degree setting, and then it took some force.
We followed the Mazda manual to the letter, even applying oil to the threads as specified (which makes a significant difference).
The head we replaced has now done in excess of 2000 miles and all seems well. (Head bolts were re-checked after 600 miles as recommended)
As far as overtightening of the glowplugs is concerned, you are far safer sticking to the Mazda recommendations (15~19Nm). Why? - Aluminium :!: Just my opinion though. :wink:
That's very interesting,how did you check the bolts after 600 miles.?
widdowson2008
Post by widdowson2008 » Sun Nov 06, 2011 7:18 pm
When we did the head bolts originally, we put paint marks on them to help going through the 90 degree tightening sequences. All we checked was that the paint marks hadn't moved from the original tightening.
One needed tweaking to get it in-line with the rest (very minute amount), but otherwise nowt to do. Couldn't see what else could be done. Engine still running sweetly though so we must have done things right. (I hope)
Steve
Post by teenmal » Sun Nov 06, 2011 8:49 pm
Hi Steve,
What do you recon the torque on the bolts are after the final tighten.
Cheers.
widdowson2008
Post by widdowson2008 » Sun Nov 06, 2011 8:56 pm
teenmal wrote:
Hi Steve,
Cheers.
Absolutely no idea. Couldn't even hazard a guess - sorry. Just followed the Mazda manual instructions.
All I know is that it is WAAAYYY above the initial torque of 29Nm.
As a very rough guide, Jeff did the final tightening (and he is an extremely fit bloke). We had a 5 foot long bar and he had to exert full body weight to it to achieve settings.
Steve
dandywarhol
Post by dandywarhol » Sun Nov 06, 2011 9:18 pm
I don't understand why the bolts are rechecked @600 miles.
The principle behing stretch bolts is to eliminate retorquing the head thus extending the initial service intervals of the vehicle. Before stretch bolts were invented, engines used conventional high tensile steel bolts which had to be retorqued at the first 1000 mile service - pretty labour intensive.
If you were to retorque stretch bolts, then you are resetting them from the stetch - thats a no no cos you should never reuse stretch bolts...................................... :?
Post by teenmal » Sun Nov 06, 2011 9:38 pm
dandywarhol wrote:I don't understand why the bolts are rechecked @600 miles.
I am a bit confused as well,
"Quote from Steve...(Head bolts were re-checked after 600 miles as recommended)
I dont know any other way of checking the bolts other than checking the torque setting.
widdowson2008
Post by widdowson2008 » Sun Nov 06, 2011 10:10 pm
Sorry Dandy/teenmal - getting old (and feeling it) :lol: .
It wasn't the head bolts we checked - it was the tappet settings.
Last edited by widdowson2008 on Sun Nov 06, 2011 10:15 pm, edited 1 time in total.
Steve
Post by teenmal » Sun Nov 06, 2011 10:13 pm
It wasn't the head bolts we checked - it was the camshaft pedestal bolts, simply because it was suggested by a mate - no other reason.
Great stuff,I will sleep better tonight :lol:
widdowson2008
Post by widdowson2008 » Sun Nov 06, 2011 10:16 pm
Cocked up again. It was the TAPPET settings we checked. I'm not paying attention.
Steve
