Page 2 of 2
cruise control
Posted: Fri Jun 16, 2006 3:20 pm
by brianwfl
Hi mrs d
enter howard mays cruise cotrol in the internet search, for all info on non vacuum cruise control. its a doddle to fit diy or steve jones can fit for you at your premises.
brgds brianwfl
Posted: Fri Jun 16, 2006 3:57 pm
by BarryS
Posted: Sat Jun 17, 2006 10:01 pm
by ferdyb
Can I just query the fitting of a speed sensor circuit to the engine of a vehicle with auto transmission? Surely, until the lock-up occurs, all the other gears are only loosely related to the actual road speed via the torque converter? So the engine is never going to be a reliable indicator of road speed.
Come to think of it, even with a manual gearbox, the engine is only in direct, one to one contact with the propshaft, and hence road speed, in fourth gear as well.
ferdy
Posted: Sat Jun 17, 2006 10:17 pm
by Dave up north
Doesnt the speed sensor connect to a pickup on the prop shaft, which is a constant with the road speed?
Dont know much about it but I think that is where it gets the speed info.
Dave
Posted: Sun Jun 18, 2006 3:09 pm
by ferdyb
Yes Dave, I agree with that, it's just that AliBongo in a post on the first page mentioned taking a feed off the coil, which would only give engine speed, which may or may not be related to road speed, especially with an auto box, I would have thought.
I admit I don't know much about it either, it all sounds far too dangerous and likely to send me off to sleep.
ferdy
Posted: Sun Jun 18, 2006 6:43 pm
by dandywarhol
I guess the most obvious place to take a speed reading would be from the electronic speedo pulse........................
Posted: Sun Jun 18, 2006 7:44 pm
by Simon Jones
I agree with Dandy - I am planning to use the speedo sensor feed, just before the km-mph convertor. Feeds from the coil are only used for rev counters & therefore are engine speed, not road speed. Most Bongos are diesel, so no coil anyway.
Posted: Thu Jun 29, 2006 8:12 pm
by AliBongo
I got my vaccum from a pipe at the front of the engine just to the offside of the water pump. On my 1996 Bongo there is a metal pipe going straight up in front of the engine with a ready made vacuum take off with a blanking pug on it. If you shine a torch in from the passenger side you should see it.
Posted: Tue Jul 11, 2006 8:46 pm
by Simon Jones
Thanks AliBongo - I'll have a look for said pipe when I get home.
