Air con fan
Re: Air con fan
Post by g8dhe » Wed Jul 13, 2011 10:34 am
jaylee
Re: Air con fan
Post by jaylee » Wed Jul 13, 2011 10:53 am
DanL wrote:Jeylee!! Think you have hit the nail on the head!!! =D> Just found a relay burnt out! Its the foward R/H, as if your looking under the bonnet. What do they all do? And more importantly, where can i get one!!!!!!
You could try comparing the relay to other Mazda models of a similar year?? MX5? (Eunos)?? 626?? Or even some mid late 90's Fords, like a Transit???!! :-k :idea: :arrow:
You may get lucky that way??
Once sourced, sounds like a simple job of plug in & play! :D
My set up on my 95 4x4 tintop in the passenger wing is different... I just have one relay bolted at the most forward position..!
So mine is either for the AC, or the factory fitted front fog loom..?? (I know the loom spur from this solitary relay heads towards the loom that runs above/in front of the AC gubbins.)
DanL
Re: Air con fan
Post by DanL » Wed Jul 13, 2011 1:58 pm
Nice piccy g8dhe! Although all my Relays are on the left hand side. Sorry got mixed up with relays & fuses, thought those chucky fuses were relays?? Doh!! :lol:
Anyhow the relay has literally melted, this has caused some damaged to one of the terminals (thick white cable). Ive tryed to clean it up & swapped relays and still no joy on getting the air con fan to kick in. I think the connector i too badly corroded, but im going to get a voltmeter on it before changing it as i looks like a pig of a job to change.
Ive found a new relay on ebay, so thats now on its way!
