round thing at back of engine ? i pressume its the starter motor which isnt connected to the coolant system.
Lift the drivers seat and look from there, because if you are looking from below it might look like its leaking from the "round thing" but it will be that pipe that goes over the starter, its weak point is were its joins the engine itself.
Either way just topping up is doing your Bongo no good as the leaking water is being replaced with air. Get the engine pan off and hunt down the leak and repair it before it knackers your engine.
coolant alarm.,bingo 2nd time
Re: coolant alarm.,bingo 2nd time
hes found the leak----over the starter hose head end.
found it thanks for ALL the help,rear heating hose .
NMOAD
NMOAD
