Under driver's seatdangaran wrote:sorry to ask but where is the fuel filter?
DO NOT DO THISbigdaddycain wrote:This, in addition with a regular italian tune should shift enough crud build up that may possibly be blocking the oil pick up pipe in the sump.
Ok, so, they are going to replace the seals. To do this requires the pump to be removed as the culprit is probably the front seal if it is the pump. It then requires a new belt and timing.dangaran wrote:Ok, spoke to garage,
they say , they thought my diesel pump seals may have gone???
£15 plus upto 2 hours labour (£90)
this sound like a conspiracy to me
bigdaddycain wrote:I agree!My post was a little disjointed, i meant an italian tune would help clear carbon deposits due to low mileage runs etc
