has my themostat failed in open?
Darkstar
Re: has my themostat failed in open?
Post by Darkstar » Sat Nov 27, 2010 8:33 am
Northern Bongolow wrote:if its stuck open,and you need the motor,try giving the stat housing a few sharp taps(dont break it in this cold weather.)the spring pressure should close it.but then watch the temps like a hawk :shock: ,in case it sticks shut.
usuall not my fault if it blows up disclaimers apply :shock: :)
i did think of trying that, but the thought of an overheat if it did stick put me off.
Got a Bongo for the Wife, Best trade-in ever
Post by mikeonb4c » Sat Nov 27, 2010 12:35 pm
bite the bullet and put a new thermostat in ASAP esp. if its age is unknown IMHO. At least it'll force a coolant change (make sure you/the garage know how to bleed it properly) so you won't need to do it for 2yrs. Pity about the cold weather though :( 8)
Post by Northern Bongolow » Sat Nov 27, 2010 8:45 pm
you could try warming everything up a bit,see if the top hose to the rad,is the same temp as the 2 pipes into the expansion tank,they should be very similar.but if the bottom hose out of the rad is the same as those 3 then the stat is stuck open.
dont run it it for more than 15mins to do this test,no need to rev it much,the results should be quickly apparent.
