White Smoke & Lumpiness On Startup - Glowplugs Fine . . .
mister munkey
Re: White Smoke & Lupiness On Startup - Glowplugs Fine . . .
Post by mister munkey » Wed Oct 06, 2010 9:19 pm
As said, the plugs have all checked out okay.
I've always given them a few seconds extra cooking time as a matter of course anyway.
M 80NGO
Post by M 80NGO » Wed Oct 06, 2010 9:21 pm
How have they checked out ok ? have they been removed and tested or have the just been checkes in situ for 12v current ?
mister munkey
Post by mister munkey » Wed Oct 06, 2010 9:45 pm
Out & benched.
mister munkey
Post by mister munkey » Wed Oct 06, 2010 10:13 pm
waycar8 wrote:Yuo have checked that the engine pre heat switch is turned off again Chris #-o :-" :-"
If it is, maybe give the valve a tap with an hammer, as you have just had the back box done havent you?, maybe sumat got lodged/dislogged in the process?
For a minute there I thought you had struck the obvious nail on the head.
Legged it out to check but sadly, its even worse with the switch on.
Post by g8dhe » Wed Oct 06, 2010 10:19 pm
Have you checked the Glow Plugs when in and working that they are getting a full supply to them and hence are coming up to temperature in the vehicle itself, rather than just on the bench ?
munroman
Post by munroman » Wed Oct 06, 2010 11:06 pm
g8dhe wrote:Have you checked the Glow Plugs when in and working that they are getting a full supply to them and hence are coming up to temperature in the vehicle itself, rather than just on the bench ?
Yes, are all the connections to the Glowplugs tight, no cracks in the Busbar? (Was the rebuild not done in a rush, so maybe as simple as a loose glowplug connection?
Maybe glowplug relay fubar?
mister munkey
Post by mister munkey » Wed Oct 06, 2010 11:17 pm
With hand on heart, I believe its nowt to do with the rebuild.
Its been happening for a couple of years but been more noticeable since early summer. Previous to new rings it was predominantly chucking out black smoke when either cold or hot (Mostly cold though). Thats now cured, as is the oil consumption problem - Good Times!! :D
As it was off the road for three months, some of my memory cells may have deterioated in the meantime but fairly certain this has got worse since the fast idle gave up the ghost.
mister munkey
Post by mister munkey » Wed Oct 06, 2010 11:21 pm
munroman wrote:
g8dhe wrote:Was the rebuild not done in a rush
Not too much of a rush.
13 weeks.
:roll:
hembramacho
Post by hembramacho » Wed Oct 06, 2010 11:38 pm
Mine gave the same symptoms as you're describing this time last year Chris. I posted about it at the time.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=35116
Went down the road of glow plugs, fuel pump seals, etc. Had the timing altered by a local recommended diesel engine specialist - didn't make much difference other than making the bongo sound even more like a tractor!
I'd had the glow plugs changed not long before, so didn't think that was the problem. Had a non-return valve fitted on the fuel filter, but TBH none really cured the issue.
Nice weather came and the problem went away.
Over the last week or so, have had a bit of chugging/smoke at start up. Putting it down to colder weather and look forward to another winter of chugging bouncy startups and an even blacker patch at the bottom corner of my white garage door. :roll:
If anyone has an answer to this, bring it on.
After the chugging/bouncing has cleared (a few seconds of pressing accelarator) bongo runs as normal, so although an irritating issue (I agree with you Chris with the embarassing smoky startup that you have to justify to collegues :oops: ), is a smoky startup during the colder winter months something I just need to accept and live with?
Andrew
mikexgough
Post by mikexgough » Thu Oct 07, 2010 6:37 am
The Bongo school of thought is usually Cold start (on northern bongo's) accidentally switched on, Cold morning and steam caused by hot exhaust mixing with cold air, Glow plugs or water caused by coolant issues..........
Now General school of thought also suggests......... Air getting in(maybe a joint not quite tight, yet when the engine warms the joint is "sealed")....... Diesel Pump timing..... Fuel brand (some folks with various Bosch pumps have had issues with V power diesel - Bongo pump is a Zexel or rather Bosch Japan) ........ So I guess the simple things 1st then move to the more complex things.......
I have to wonder if the fast idle may need to be checked for setting(s) too....a methodical approach needs to be the order of the day....
Tripewriter
Post by Tripewriter » Thu Oct 07, 2010 7:10 am
Could be time to drain your fuel tank! Never know what is in there partcularly if using bio-diesel or Veggie.
gmaczbongo
Post by gmaczbongo » Thu Oct 07, 2010 1:55 pm
I would still let the engine builder have a wee look if he is close by.
Could be a wee tweak needed and all is well.
Post by g8dhe » Thu Oct 07, 2010 3:30 pm
13 weeks.
:roll:
Duh I think the quotes got mixed up there, that wasn't me at all !
Umm
Post by Umm » Thu Oct 07, 2010 4:14 pm
Umm has similar symptoms on start with smoke not particularly white but after 5-10 secs runs sweet as a nut
Always been like it but slightly worse now cooler
Will look at all the suggestions here but until found this thread assumed was normal
Si
mulshy
Post by mulshy » Thu Oct 07, 2010 4:31 pm
My main headache is the ribbing I get from the workmates when I fire it up after its sat for a 10 hour shift & seem to enjoy the fact that I chug out of the yard belching like a steamroller at the end of the day.
I just want to bring a bit of Kudos back to the old beast.
i find telling them i'm chugging off up the highlands again works :mrgreen:
all the same but different
