Re: Cruise Control, Taking the plunge
Posted: Sat Aug 28, 2010 10:31 pm
Do the 626's have central locking Modules that will plug in? My snob of a hubby has got 1 upwomenship with posh get away unlocking
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
Certainly don't stick it in the crusher - YET.mister munkey wrote:No idea if its relevant but I have a spare V6 MX6 which is about to be scrapped but before I bin it I'm pulling off all the relevant compatible Bongo bits - Obviously.
One of the nicer features of this old girl is the original Mazda cruise control with all the control gubbins on the (same as the Bongo) steering wheel. It looks very smart.
Is this of use to anyone with the savvy to retro fit to a Bongo or should it go to the crusher?
Pull at the very end of the T of the pipe - I spent too long pulling with my pliers on more of the length of the pipe only to find I was making it difficult - the pipe is slightly bulbed at the end so I was applying pressure that was squeezing the rubber onto the pipe rather when I was trying to pull it off.Bob wrote:Don't try and use Scotchlocks as the Bongo wire is too thin for a good contact, and as said you don't need to cut any pipes for vacuum take off.
Lift passengers seat and at the front of the engine is a vertical vacuum pipe with a small T take off. Remove the rubber cover by pulling the very end with a pair of pliers, then push fit the pipe from your sensor.
