Tail light, side light and dash circuit failed
Re: Tail light, side light and dash circuit failed
Post by Northern Bongolow » Sun Feb 20, 2011 11:58 pm
upwards------------slip the top portion off the plugs/wires stay put. you unbolt them first ,then remove the hanger,then unclip them from the wire/plug end.
dblake
Post by dblake » Mon Feb 21, 2011 12:03 am
I had my tail/side/dash lights fail about 3 weeks ago - got a relay from bongobits delivered for about £13. Couldnt manage to remove mine from the metal bar so unscrewed the whole lot lol
Have only got the 3 relays in mine - but do have foglights so am a little puzzled now! lol
Post by g8dhe » Mon Feb 21, 2011 12:08 am
dblake wrote:Have only got the 3 relays in mine - but do have foglights so am a little puzzled now! lol
If someone has fitted the front Fog lights as an after market item they may not have used the installed loom or relay position (they may not have used a relay at all :-( )
dblake
Post by dblake » Mon Feb 21, 2011 12:18 am
it's really odd as i had to replace a cracked lens on one of them and by the looks of the fittings, switch etc they've been there forever! Could they be "driving lights"?
Simon B
Post by Simon B » Mon Feb 21, 2011 9:47 am
Tried swapping headlight and sidelight relays. Headlights still work but sidelights don't. :roll: Unless mine aren't in the same order as the ones pictures above. I'm a bit stuck now.
Any more ideas? :idea:
jaylee
Post by jaylee » Mon Feb 21, 2011 10:10 am
Simon B wrote:Tried swapping headlight and sidelight relays. Headlights still work but sidelights don't. :roll: Unless mine aren't in the same order as the ones pictures above. I'm a bit stuck now.
Have you tried checking continuity in the connector on the loom to the relay?
Simon B
Post by Simon B » Mon Feb 21, 2011 10:20 am
No, I haven't got a meter to test it with, and if I did I wouldn't really know what to do with it anyway.
I had the dash in bits on Friday to swap the speedo face and I had to disconnect the foglight switches, but all the lights were working after I put everything back together again.
Simon B
Post by Simon B » Mon Feb 21, 2011 10:37 am
Thanks for all your replies and help. :D
Unfortunately I am a numpty :oops: Had a cup of coffee and a re-look at the fusebox fact sheet. I didn't check the fuses under the bonnet initially.
I have now and No. 8 (rear lights) had blown. Swapped it for the foglight fuse and side lights and dash back lights now working.
Croz
Post by Croz » Thu Feb 24, 2011 6:02 pm
I suffered this problem yesterday :( Found out on starting up after a more prolonged lay off using my Bongo than usual but not sure how long it may have been there as I haven't used the Bongo after dark for about 6 months!!
I have isolated the relay and checked by swapping them around which one has failed. I carefully opened it and found condensation inside but on drying and reassembly had no luck. Strange actually as it looked in good condition inside.
I tried to get a replacement in Halfors and a local Mazda dealer but no luck (Mazda needed chassis no and time to order............).
I really need to have one fitted by Tuesday as I am booked for a meeting/camp 250 miles away from Wednesday for a week - Can anyone help please :)
Croz
sibot
Post by sibot » Fri Sep 09, 2011 10:01 pm
I suffered this same problem this evening. Tracked it down to the relay, swapping in one of the others fixed it, but I'm guessing none of the 4 in place is actually spare ? :lol: Having said that - I do have 4, and no foglights fitted (but wiring in place for them). What do the other relays in here do - is there an easy way for me to check if one of them is indeed spare? Had to delay a trip to sort this out, and I don't expect Halfords to have any suitable relays in stock?
sibot
Post by sibot » Fri Sep 09, 2011 11:02 pm
So, diligent application of a multimeter seemed to indicate the order of the relays, from back to front, or left to right as you are looking at them, is:
tail light/side light/dash circuit
Headlamp circuit
Don't know - blue connector
Fog lamp circuit
Having no fog lights fitted, I swapped that one for the tail light circuit and everything seems to work. Now I just need to find a replacement - will any 20A 4-pole relay do or do I need to get a specific Mazda one?
Post by missfixit70 » Fri Sep 09, 2011 11:16 pm
Tis just a relay, may be worth popping it open, may just be a wire needs resoldering or contacts cleaning, not much to them to be honest, this may help - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=51193 - admittedly not the same relay, but they're all basically the same - a coil & contacts.
If it's a no go, then this one may help find a similar spare - http://www.igmaynard.co.uk/bongo/forum/ ... ht#p336605 - but as you say it's just a normal relay, so any similar rated one will do the job fine.
sibot
Post by sibot » Fri Sep 09, 2011 11:24 pm
Cheers, will give that a go over the weekend and see how i get on.
Post by teenmal » Sun Sep 11, 2011 10:19 am
Hi,if you can find this image from g8dhe in his post (Feb 20 2011) it shows the relays and their function.I think it was, looking from left to right or back to front.
Head lights
Side and tail
Airconditioning High and LOW
Fog Lights
Cheers..
