Fuel Pump bleeding
Re: Fuel Pump bleeding
Post by g8dhe » Mon Aug 09, 2010 10:03 am
Paramedic Training Instructor ?
Given that a V6 doesn't have a vacuum pump are there any vacuum pipes ?
Post by haydn callow » Mon Aug 09, 2010 10:17 am
Loads of 'em on mine...
jaylee
Post by jaylee » Mon Aug 09, 2010 10:50 am
Post Trauma Insertion of... a.....?? needle with drugs in........? :-s :? :? :mrgreen: :oops: :oops: :oops: :roll:
Post by missfixit70 » Mon Aug 09, 2010 12:40 pm
haydn callow wrote:Loads of 'em on mine...
EGR diagram? - http://www.lushprojects.com/bongopartsm ... mgno=.html
affaj ekac
Post by affaj ekac » Mon Aug 09, 2010 1:37 pm
g8dhe wrote:Paramedic Training Instructor ?
Think I may need a paramedic by the time I am finished on the Bongo!!
Post by haydn callow » Mon Aug 09, 2010 1:49 pm
Thanks Kirsty
What section is that under....thought I'd looked everywhere
affaj ekac
Post by affaj ekac » Mon Aug 09, 2010 2:28 pm
Northern Bongolow wrote:check the air vacuum pipes that are on the pump,sounds like not a fuel leak but an air leak imo
oh and welcome
Ady,
checked the pipes but nothing obvious, the hiss when it stops is even more obvious and sounds like it bubbles a bit for a few seconds after, sounds likfrom rear end of pump. Is there an air bleed screw/bolt or am I clutching at straws!!!!
cheers
Post by Northern Bongolow » Mon Aug 09, 2010 2:53 pm
dont know the v6 pump so i will butt out :lol:
Post by missfixit70 » Mon Aug 09, 2010 4:27 pm
haydn callow wrote:Thanks Kirsty
Around the engine (V6) - egr system
Post by haydn callow » Mon Aug 09, 2010 4:57 pm
Simples !!! when you know where to look....thanks
Post by missfixit70 » Mon Aug 09, 2010 7:26 pm
oh and welcome
Ady,
cheers
Is there any sign of fuel leakage around the pump? common problem for seals to go, fact sheet in the members area or info on here if you do a search on "Fuel and pump and seals", diagram here - http://www.lushprojects.com/bongopartsm ... mgno=.html
munroman
Post by munroman » Mon Aug 09, 2010 7:59 pm
Maybe the return pipe from the fuel rail, there have been some reports of it becoming porous.
affaj ekac
Post by affaj ekac » Mon Aug 09, 2010 11:55 pm
Thanks to all for the help. I managed to get it running best it has ever been. I manual pressed the wire under accelerator wire that leads to what i think is the vaccum pump. This seems to have worked for now and as i am probably out my depth for anything more i will run it to a garage and see if they can check all the hoses etc. Many thanks for all the advice, the forum and stuff on here is great for the complete novice like me who wants to try and do some self help.
Steph :) :) :) :) :) =D>
affaj ekac
Post by affaj ekac » Mon Aug 09, 2010 11:58 pm
munroman wrote:Maybe the return pipe from the fuel rail, there have been some reports of it becoming porous.
thanks munroman I have got it running now but as i dont know what a fuel rail is I will stop there and be glad ive fixed it for now. Think you may be right though if its the pipe i think it is looks shabby!
Steph :)
