V6 engine noises...
Re: V6 engine noises...
Post by g8dhe » Mon Jul 05, 2010 3:01 pm
fivepints wrote:(Incidentally, I also have three empty bolt fixings on the engine block which I assume are not required - anybody know what should/should not/could potentially go there? Indicated with red circles).
Same on ours, no idea what could fit there I'm afriad.
fivepints
Post by fivepints » Mon Jul 05, 2010 3:02 pm
No worries - kills that concern :lol:
2000 Imperial V6 - White over silver - Chesham doesn't know what's hit it!
cheffy34
Post by cheffy34 » Mon Jul 05, 2010 3:11 pm
does it happen when you got your aircon on by any chance :?: I'm sure it is the aircon pump there [-o< waterpump in the middle ish. Power steering, altinator under the driverside along with the filler cap, the altinator is hard to see from up top it sits directly below the p/s pump me thinks:wink:
Ps i have a few strange noises on mine, the valve which you can see in the pic begins to click with age when driving at low speeds it's noticeable more when you have the passenger window open, mine has done since i owned it :roll: it is to do with the egr [-o<
Dar
fivepints
Post by fivepints » Mon Jul 05, 2010 3:24 pm
Yes, air-con has been on since I picked it up last week 'cos of the weather. Would that be tied to revs though? Will try driving home with the air-con off to see what happens. Will also attempt to record the noise - although that usually doesn't work!
cheffy34
Post by cheffy34 » Mon Jul 05, 2010 6:52 pm
Probably:!: i don't know for sure :roll: , when it is turned off i think the compressor free wheels on a clutch kind of thing , try it when it parked engine running turn aircon on see if it happens :wink:
I wish my noise was an accessory :cry:
Hope yours is :wink:
fivepints
Post by fivepints » Mon Jul 05, 2010 7:22 pm
OK, noise continues with air-con off.
Is the item I've highlighted in the pic actually the alternator? Think I'll drive to work with the passy seat up tomorrow, will keep the windows open!
cheffy34
Post by cheffy34 » Mon Jul 05, 2010 8:02 pm
it could still happen when off i think, i would take the belt off to see, and i'm sure it is the aircon compressor under the passenger seat
dandywarhol
Post by dandywarhol » Tue Jul 06, 2010 12:01 am
V6 kinda prone to camshaft/followers wearing causing a grinding/rattling noise. Has it only happened SINCE the cambelt work was done?
fivepints
Post by fivepints » Tue Jul 06, 2010 1:28 am
dandy, no idea unfortunately, cambelt was changed by dealer on purchase. Didn't hear it during the test drive but then I wasn't listening out for it!
fivepints
Post by fivepints » Tue Jul 06, 2010 11:51 am
Imperial have put me in touch with a travelling Bongo expert - John Black - well respected I hear. He's coming out tomorrow night so fingers crossed it's an easy fix!
cheffy34
Post by cheffy34 » Wed Jul 21, 2010 7:32 pm
Any outcome on this one fivepints :?:
Dar
fivepints
Post by fivepints » Mon Jul 26, 2010 2:23 pm
Yes - apparently the heat shields from the exhaust manifold were corroded and rattling, John fixed them back on. That said - the noise is still there! I'm getting more and more convinced that it's exhaust related.
cheffy34
Post by cheffy34 » Mon Jul 26, 2010 9:32 pm
My heatshields were vibrating nout A HAMMER DIDN'T SORT :D
Post by haydn callow » Mon Jul 26, 2010 10:20 pm
I'll have a look round mine tomorrow....is that not the A/C pump/compressor ?? I'm nor sure but will look in the morning..
I get no "extra" noises from mine at any speed/revs.
cheffy34
Post by cheffy34 » Mon Jul 26, 2010 11:18 pm
Tis Haydn :wink:
Dar
