oh dear coolant issues.
spana
Re: oh dear coolant issues.
Post by spana » Sun May 23, 2010 10:32 am
too right, i will try and upload pictures this evening showing the particles, but they would definatly be big enough to cause blockages in heads, pumps, stat housings etc.
atleast its a loverly day to be undera bongo in a pool of water?! lol
Post by rita » Sun May 23, 2010 10:37 am
Hi spana,
Sorry to hear about your problems,I would be concerned about the (plume of blacky blue smoke)if it still exists.
I would also get your vehicle checked out by a mechanic before you start throwing money at it.
All the best...
spana
Post by spana » Sun May 23, 2010 11:43 am
smoke seems to have gone?! just put some flushing liquid through it and warmed it up slightly.
now time for a sit in the garden whilst it cools down to drain, re-flush and then re-bleed. :evil:
Post by Northern Bongolow » Sun May 23, 2010 12:19 pm
the oil cooler and its contents are made from copper, the internals of the oil cooler are very soft and bright copper,the body is 1mm sidewall hard brittle copper.someone may have put a foreign body in.
steve i will sort her/it out.
ady
spana
Post by spana » Sun May 23, 2010 12:26 pm
am i right in thinking its the oil cooler attached under the rad thats made of copper?
if so, should i exspect to find water in my oil cooler aswell?
Post by Northern Bongolow » Sun May 23, 2010 12:31 pm
no the oil cooler is IN THE BOTTOM 2 INCH OF THE RAD if this has poped its contents of copper gauze like material would be released into the coolant system.also you could have coolant in your gbox if its an auto.check the g/box on the dipstick and its condition.
spana
Post by spana » Sun May 23, 2010 3:02 pm
it is an auto, gearbox oil just looks like oil, pinky in colour and up to the full line.
going to call ian taylors i think, ive wasted the last 2 days on it and it's not made the blindest bit of difference. :cry:
looks like i'll have to cancel my bank holiday away and put some bloody overtime in. #-o
Post by Northern Bongolow » Sun May 23, 2010 4:17 pm
good luck,please keep us informed,as this is a weird one.
spana
Post by spana » Sun May 23, 2010 4:48 pm
i shall, i love this forum, everybody is so helpfull and knowledgeable. :)
widdowson2008
Post by widdowson2008 » Sun May 23, 2010 4:55 pm
All been in your spot at some time or other regarding knowledge (or lack of). :wink: Some of us still are :oops: :lol:
Steve
spana
Post by spana » Mon May 24, 2010 9:43 pm
just a quick update, phoned ian taylor's today. he rekons its most likely the head has gone, the copper in the coolant is an additive put in by the previous owner?! it may have caused damage to water pump etc....
i shall be dropping it off on wednesday for him to check over and then repair. so fingers crossed its not anything more [-o<
looks like ive been screwed over, which is quite annying really :cry:
Post by missfixit70 » Mon May 24, 2010 10:30 pm
At least it's in the right place to get sorted.
Did you get it for a good price? I'm afraid if you bought it "as seen" that would have rung alarm bells with me, ie why is it being sold on just after having a load of work done/money spent on it?
You've got a pm.
Post by haydn callow » Mon May 24, 2010 10:34 pm
I think this situation is going to be happening much more often as more peeps resort to "steel seal" to effect a short term fix.....I can understand why it is done but 6 months later when perhaps the vehicle is still running fine and it's time to sell. Are they going to declare that the head/gasket went months ago and they fixed it with "steel seal" (or whatever)
spana
Post by spana » Tue May 25, 2010 4:05 pm
i got it relativly cheap i supose, got a "free drive away awning and sun shades two" but to be honest, i'd have given them up for a wagon that actually worked lol.
just been in to see the garage that put the head gasket on it, basically they were told, "sort head gasket out as cheap as poss as im selling it" apparently head went away to the company that they deal with to pressure test etc, it "had gone between 2 and 3"
so it was skimmed and painted up etc, then re installed.
the garage had problems bleeding system so left the stat out at owners request.
they did no investigation as to why the head went in the first place or took any other measures to stop it happening again!
going to drop it off tommorow at ian taylor's and exspect some big bills #-o
spana
Post by spana » Fri May 28, 2010 2:36 pm
another quick update, dropped it off at ian taylor's last night. hes 99.9 percent sure its the head, even more specifically,hes norowed it down to a crack in cylinder number 2, just around the back of the exhaust port, and he hasnt even taken the head off yet.. i take i he knows a thing or two lol...
now just to get to the bottom of why it went in the first place :?
