240v to 110 via transformer
stilldesperate
Re: 240v to 110 via transformer
Post by stilldesperate » Mon May 03, 2010 4:46 pm
Hi Jackasti,
Mine is Red (pin 3) is Live, White (pin 2) is Neutral, and Black (pin 1)is earth.
I did a "how to" sheet for this a while ago, I think Rhod did the mod from my sheet, I built the Maplin step-down transformer into the kitchen cube, so you just run a site lead (with a RCCD) to the van, and the jobs done.
BTW, if you've taken off the Japanese input socket, do you have the plug spare on the end of the hookup lead? I need a spare, happy to buy if so.
I'll PM you my number if you need to chat.
SD
"The older I get, the faster I was"
jackasti
Post by jackasti » Mon May 03, 2010 5:28 pm
A great big thanks to all you Bongo Nuts. I now have all the info I need to crack on and wire up the cube. Does`nt mean that It will work but with a bit of luck I should'nt fry myself
Jackasti.
