running hot !!
Re: running hot !!
Post by haydn callow » Sat Apr 10, 2010 1:13 pm
In addition to the above...I have found that reading the cylinderhead temp from a "bolt on" sensor positioned at the rear of the cylinder head is normall within 2C of the coolant exiting the head via the hose in question.....most of the time it reads the same but when the temp fluctuates it lags behind by a few secs and a couple of degrees
widdowson2008
Re: running hot !!
Post by widdowson2008 » Sat Apr 10, 2010 1:34 pm
They look OK Haydn :D Do you include the sensor fitted?
oops ..............I have only just realised, we have hijacked tuftyfreers post - has anyone heared from him/her re the ORIGINAL subject matter?
Tufty??????????are you there?
Steve
tuftyfreer
Re: running hot !!
Post by tuftyfreer » Sat Apr 10, 2010 5:52 pm
yeah still here, you lot are in different league im completly lost as to what your all going on about but interesting reading keep up the good work. Bongo mechanic coming next week to have a look going down the pub now to spend my winnings did okay on the national. Thanks for all the advice and help let you know the outcome.
laters guys
Mountain
Re: running hot !!
Post by Mountain » Sat Apr 10, 2010 6:43 pm
Hi tuftyfreer,
I'm a Bongo noob too :D
If it's any consolation my first week of ownership was a disaster....then things got worse :shock: This was due to some serious neglect by the previous owner.
On the plus side my mother has had Bongo for around 3 years. It's her daily drive and she does a fair few miles in it too. She's never had a problem with it. Proof that they are a good vehicle when properly looked after.
However, after my experience,my dad(retired mechanic) is now checking the coolant system over with a fine tooth comb and is going to fit a low coolant alarm and replace the main hoses too.
In my very recent opinion....Finding a good Bongo mechanic and having things checked over is certainly a good idea. As are any alarms properly fitted. Regular coolant level checks should be part of your routine (regardless of what vehicle you own!).
So you are definitely doing the right thing, for peace of mind if nothing else :D
tuftyfreer
Re: running hot !!
Post by tuftyfreer » Sat Jun 05, 2010 8:23 pm
hi guys quick update and more advice please had the coolant changed fitted new mazda stat running temp went right down very happy. Mechanic said coolant senser was nackerd and the engine fans were not working so had new one fitted temperature back up is this an airlock in the system ? or something more sinister mason is set at 4/5 and bleeps occasionally on hills or at high speed.On to a different subject is it possible to sand out a paint run without respraying.
thanks everyone for the help.
dext924
Re: running hot !!
Post by dext924 » Sat Jun 05, 2010 8:48 pm
I have my sensor at the back of the engine block as suggested by Haydn. On a good long run this week, mine sits at 84, creeping up to about 90 if I am stuck in traffic, (and this hot weather!!) My temp needle stays happy at about the 11 o'clock on the gauge
However, I have just the digital temp/volt sensor, not the dual one, so not sure how they work in comparison, but surely they must be calibrated the same?
Anyway, thats my ten pence worth, hope its some use
