Expansion tank query
Re: Expansion tank query
Post by g8dhe » Mon Mar 29, 2010 1:23 pm
Yup it doesn't sound like any sacrificial anode to me.
Post by haydn callow » Mon Mar 29, 2010 2:09 pm
defo not one in either of mine
widdowson2008
Post by widdowson2008 » Mon Mar 29, 2010 2:50 pm
haydn callow wrote:defo not one in either of mine
Are you absolutely sure about that? Have another look.
Steve
Post by haydn callow » Mon Mar 29, 2010 4:34 pm
Absoloutly certain ....I have just looked "again" at a spare tank......There is quite a high flow through the tank so any restriction would not be helping the cause
widdowson2008
Post by widdowson2008 » Mon Mar 29, 2010 6:26 pm
haydn callow wrote:Absoloutly certain ....I have just looked "again" at a spare tank......There is quite a high flow through the tank so any restriction would not be helping the cause
Where are you looking because this cannot actually be seen unless the tank is physically split open.
Steve
Post by haydn callow » Mon Mar 29, 2010 6:32 pm
Trust me...it is not there on my spare tank.........I can see down both holes and ther are totally unrestricted.....I also split and cut up a tank a couple of years ago....that also did NOT have whatever that object is.
widdowson2008
Post by widdowson2008 » Mon Mar 29, 2010 7:17 pm
haydn callow wrote:Trust me...it is not there on my spare tank.........I can see down both holes and ther are totally unrestricted.....I also split and cut up a tank a couple of years ago....that also did NOT have whatever that object is.
The reason I am a bit persistent in asking is that Mike at Wheelquick told me that particular tank is definitely from a 2.5 diesel. Somebody is wrong.
OR
that particular gizmo (whatever it is) was put in some and not in others???????
I'll hopefully be getting my own to chop up soon. :wink:
I WILL FIND OUT :evil:
Steve
Post by haydn callow » Mon Mar 29, 2010 7:34 pm
whether the one you cut up has a gizmo in or not....mine hasn't
The Great Pretender
Post by The Great Pretender » Mon Mar 29, 2010 10:43 pm
It is possible to put a coat hanger ect through with the restrictor in place.
A better view of it whatever it is.
And it broken off.
To infinity and beyond
widdowson2008
Post by widdowson2008 » Mon Mar 29, 2010 11:13 pm
haydn callow wrote:whether the one you cut up has a gizmo in or not....mine hasn't
For the record, I didn't cut one up, as I have repeated several times in this post. All I have seen are the pics at the beginning. And having read TGP's last post, there doesn't appear to be owt in there (unless that bit dislodged should be attached to summat)
NOT a bloody clue :lol:
Steve
mister munkey
Post by mister munkey » Mon Mar 29, 2010 11:22 pm
I'm liking this thread.
Its like watching a developing Open University course in coolant management.
Keep it up chaps. =D> =D> =D>
ebygum or tonic may well donate to the cause. . . . .
Post by Northern Bongolow » Tue Mar 30, 2010 1:37 am
hi, are the divisions actually cross braces to stop the exp tank swelling under pressure/heating.things like this are fitted to large fuel/oil tanks to brace the sides so the manufacturers can make them thinner.
on a simmilar subject has anyone found anything that will clean out the staining in a discoloured tank? im going to try a few chemicals tomorrow on a dirty one i have lying around.
Post by haydn callow » Tue Mar 30, 2010 8:50 am
You won't get the tank very clean as the brown staining is not on the surface...the plastic is stained right through.....more like "ageing" and if you have had a overheat" then it is worse,,,,The "baffles" give the tank great strength and stop "slopping"
That "restriction in TGP's does not look like the one at the start of this topic.....it just looks like the metal outlet pipe is protruding into the tank....that pipe is there to strengthen the plastic pipe and allow a decent clamp to be applied.
The one at the start of this topic has something across the opening if this pipe.
widdowson2008
Post by widdowson2008 » Tue Mar 30, 2010 8:51 am
Northern Bongolow wrote:hi, are the divisions actually cross braces to stop the exp tank swelling under pressure/heating.things like this are fitted to large fuel/oil tanks to brace the sides so the manufacturers can make them thinner.
Hi all
Just received some pics which show pretty conclusively that there is nothing at all in the tube, It appears to have been an optical illusion (and a pretty good one at that)
Northern Bongolow - The cross bracings (egg box) construction certainly adds massively to the constructional strength. It would also prevent the contents 'sloshing' around within the tank, much the same as the divider plates do in petrol/milk tankers.
Cleaning? I recently followed a link by Kirsty on the subject of cleaning expeansion tanks and someone was using Coke (of all things) - but if it works, what the hell.
...and to mister munkey - sorry to dissapoint but as far as I'm concerned it's QED. Was interesting and at least I know what the inside of the tank looks like, but there appear to be no UFO's in there. :( :( :lol:
and to Haydn, apologies for doubting you
Steve
widdowson2008
Post by widdowson2008 » Tue Mar 30, 2010 8:56 am
haydn callow wrote: You won't get the tank very clean as the brown staining is not on the surface...the plastic is stained right through.....more like "ageing" and if you have had a overheat" then it is worse,,,,The "baffles" give the tank great strength and stop "slopping"
Bugger - you beat me to it, but at least we agree on that lot.
Steve
